Old 08-22-2006, 06:06 PM   #1 (permalink)
prodigy cable
I have a '04 KC XE. I understand the under dash plug for a controller is not the same one that is on the other titans. could someone who knows what the XE plug looks like take a look at the prodigy page where the various cables are listed and tell me if one of them might fit - most likely, the toyota:
http://www.tekonsha.com/tbsabrakeconwireharn.html
thanks!
juma
Old 08-23-2006, 09:45 AM   #2 (permalink)
QWIKWHIP's Avatar
Re: prodigy cable
I'm pretty sure it has been determined that the 04 XE KC Titans are the only ones that are not prewired for the brake controller. The plug is the same for all Titans, I just don't think you have it.
Old 08-23-2006, 10:00 AM   #3 (permalink)
Derwud's Avatar
Re: prodigy cable
Some of the early '04 XE's did not come pre-wired, to check if yours is one of those go to this thread.
Brake Cntroller hook up.
Also check at the rear bumper to see if you have a round plug with 7 wires going to it. It will be on the left frame rail area near the bumper bracket.
If your truck is not pre-wired, they have kits to install the 7 wire plug and it's pretty easy.
Also if it is not pre-wired, just use the universal harness that comes with the Prodigy.
Old 08-23-2006, 04:15 PM   #4 (permalink)
Re: prodigy cable
ok, comparing photos, it does look like the prodigy toyota connector plug will fit the 04 KC XE 2WD truck for plug and play. thanks to all. may have to move some wires around in it but I think it will make it work without splicing.
juma
Old 08-23-2006, 04:19 PM   #5 (permalink)
Derwud's Avatar
Re: prodigy cable
Um no. If you have that white plug under your dash, get the Nissan plug and play adaptor only.
Old 08-24-2006, 06:38 AM   #6 (permalink)
QWIKWHIP's Avatar
Re: prodigy cable
Yeah what he said. ^^^ If you have the prewiring, then get the right plug.
Old 08-24-2006, 04:41 PM   #7 (permalink)
Re: prodigy cable
ok, got it...the plug I am looking for has been identified by "carter"
Titan XE's are pre-wired for a brake controller
does anyone have a pic of that particular plug?
hey derwud, what comes in the hitch kit? does it provide the thing the ball attaches to also?
thanks in advance!
juma
Old 08-24-2006, 08:08 PM   #8 (permalink)
Derwud's Avatar
Re: prodigy cable
thanks in advance!
juma
Hitch, 7 pin connector, 2 or three relays.
Best to measure your trailer ball height with the trailer level and get the right drop shank at wal-mart.
FS: Tekonsha Prodigy Brake Controller Vegas04 Buy/Sell 3 07-26-2006 03:04 PM
Prodigy Brake Controller bclmread Titan Parts & Accessories 10 07-10-2006 02:13 PM
Prodigy brake controller question... HudsonValleyTitan Titan General Discussion 4 05-17-2006 03:16 PM
Prodigy Controller Question....HELP scubastud Titan General Discussion 3 06-20-2005 06:26 PM
Prodigy brake controller help. Skipete Titan Towing & Hauling 10 05-03-2004 01:32 PM
