Re: Towing a Minivan
My father was an antique car nut and as his heath declined, I started towing vehicles nearly every weekend for him. I’ve towed many cars including antique Model T’s, a 48 Studebaker, my son’s Chevy C-2500, and my father’s little POS Isuzu pickup. Thclimer and Konigfritz have made good comments about the break in and speed. I’d follow their advice. I’ll just chime in on the trailer vs tow bar.
I used a flat double axle trailer to haul the T’s, Studebaker, and Chevy. The Isuzu had a tow bar and I have hauled it with the bar and on the trailer. I’ve also hauled my mother’s Oldsmobile on a dolly. (I should mention that my father owned the trailer and dolly, my experience with rental trailers and dollies is limited)
If I were towing another vehicle 1,200 miles, I’d use a trailer. I’m not a fan of tow bars. The disadvantage of the trailer is that it adds some weight, but the Titan can handle it, and there are several advantages to using a trailer.
First, the trailer will have brakes and you’ll need them to stop all of that weight behind you, especially if the roads are wet. Rental trailers use surge brakes and you wouldn’t have to install an electric brake controller. Installing a brake controller is very easy, but a good one will cost between $100 and $200.
Some vehicles tend to wander when they are on a tow bar. It is usually more annoying than anything else but it gets worse as you go faster and in windy conditions or if you put some cargo in the minivan. My experience is that a trailer tends to track better than a vehicle on a tow bar and you can move the vehicle forward or backward on the trailer to adjust tongue weight.
One thing that should not be overlooked is the tranny on the minivan. Many vehicles can’t be towed any distance without damaging the transmission. The owners manual for the minivan should provide this information. A trailer will make sure you don’t damage the minivan.
A middle of the road option might be to rent a dolly from U-haul. You can put the front wheels of the minivan on the dolly and eliminate the transmission concerns. I’ve used dollies in the past and never had problems with the towed vehicle wandering. Another advantage is that most rental dollies also have hydraulic brakes although you only have brakes on two wheels with a dolly.
