Old 12-19-2006, 10:29 AM   #16 (permalink)
ptgarcia's Avatar
Re: Best helper springs for ride and hauling?
Originally Posted by gerry
Does anybody know if i put a u-bolt on the front and rear leaf spring would it stop the axle warp from happening or just mount one on the front part of the leaf spring instead of putting a leaf spring helper.
Sure it will help, but it will make for a stiff ride. If you clamp the springs down they can't work as designed.
Pauly
Old 12-19-2006, 10:33 AM   #17 (permalink)
sudden urge's Avatar
You would only need 1 clamp at the front part of the spring where that 5/8" spring gap is. That will preload the spring and eliminate the axle wrap, but it also harshens the ride and lowers the rear by a 1/2".
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 12-19-2006, 03:37 PM   #18 (permalink)
gerry's Avatar
Send a message via Yahoo to gerry
thanks for the input i did end up puting one u bolt on the front part of the spring but i still have a little of axle warp
gerry is offline   Reply With Quote
Old 12-19-2006, 03:53 PM   #19 (permalink)
I took off the $22 helpers and put on the Deaver 1" mini-pack in place of the overload leaf. I am not noticing any axle wrap and the ride is much softer.
http://www.prgproducts.com/images/pr...comparison.jpg
Old 12-23-2006, 08:38 PM   #20 (permalink)
blueskys's Avatar
I have had the Roadmaster Active Suspension on for about half a year now. I like it.
It does more than just help overload. It helps control also. And the rear axle glides over bumps real soft like. Installation was simple. The only downer was, I needed to remove the rubber roller over the leaf spring to install. It turned out to be no big deal though. 200 bucks online.
blueskys is offline   Reply With Quote
Old 12-23-2006, 08:52 PM   #21 (permalink)
I had the Roadmaster Active Suspension on a Tundra for about 2 years.Workrd great.Cant wait to install on the Titan.
jbone is offline   Reply With Quote
Old 12-27-2006, 03:19 PM   #22 (permalink)
Originally Posted by ptgarcia
You only need 5 p.s.i. minimum in the bag at all times, unless the Titan-specific bag is different.
Yep, it even came with a sticker that says 10 psi Min
2006 Titan LE CC BT 4X4
Offroad pkg
DVD
Nav
Prodigy
WD hitch
Sway control
AEM brute force CAI
Firestone Air Bags
Magnaflow Cat Back
Fire and Ice LED
adamsrk is offline   Reply With Quote
Old 12-28-2006, 12:08 AM   #23 (permalink)
RobKar's Avatar
I have the AirLift bags ... work great with the TT attached
The Ride has improved
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 01-08-2007, 09:50 AM   #24 (permalink)
Wiscdave's Avatar
Never reported on this thread my desicion: I went with the Hellwigs and the difference was instant. Back end came up about .5 to 1 inch unloaded and with the wheeler in the back or a load of wood it has 0 sag (wood could weight 1,000lbs ). I have them pretty tight and will probably adjust them in the spring when things thaw out and try playing with different settings, right now the nuts are way up the u bolts. Towing is nice and right on, with the rear end bounceyness (if that is a word) is all but gone loaded. I like to put my 600lb wheeler in the back while towing my 4500 boat and before it would be maxed out on the springs appearing flat. Where now its right on with better braking control and steering feel as the weight is kept on the front wheels, instead of the back end making the front end stand straight up and people flash me at night thinking I have my brights on. Unloaded the ride is still softer than the offroad titans and with over a 1/2 tank of gas unnoticable. Next on the list tires and possible lift.
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
Old 01-08-2007, 10:13 AM   #25 (permalink)
Derwud's Avatar
Where did you get them from and do you have a part number?
Derwud is online now   Reply With Quote
Old 01-08-2007, 10:29 AM   #26 (permalink)
Wiscdave's Avatar
[SIZE=2]1517N Nissan 2004-06 Titan - 1500 lbs helper springs (pair) $149.95
http://www.suspensionconnection.com/...con/1517N.html
Suspension connection had the best price and fast shipping. [SIZE=2]
[/SIZE][/SIZE]
Old 01-10-2007, 07:46 AM   #27 (permalink)
That's what I was going to say....get a set of Deavers from PRG. They will make a huge difference.
06 Titan White Crewcab LE 4X4, Banks Cat-back, Volant CAI, PRG leveling kit, Bilstein rears, PRG Off-road traction bars, 33x12.5x18 Toyo Open Country M/T's, XM satellite, HID headlights and fogs, SE Offroad skidplate, Trutrac Rear Differential..........SOLD
2007 Armada LE 4x4
2007 G35 6spd sedan
g356gear is offline   Reply With Quote
Old 01-15-2007, 03:10 PM   #28 (permalink)
I too have the Roadmaster Active Suspension kit on my 05 King Cab. I am pulling a 30' 5th wheel with about 1100 lbs in the bed when towing. Works great! When bed is empty, get original ride. Did the install myself in less than 2 hours. Google Roadmaster Active Suspension for prices.
JAM21 is offline   Reply With Quote
Old 01-15-2007, 04:05 PM   #29 (permalink)
Does it use airbags? 2 or 4? How do they hold up - sounds like a nice system. I need some work on mine for sure - looking at sway bar, traction bars, everything. Just put a Timbren SES on as an emergency patch for my long trip - I'm on vacatation. Seems to help with load, but not with axel wrap.
2006 Titan SE FFV KC 4WD, Galaxy Black, Big Tow, SE Popular Pk, OEM Fog Lights, OEM Hood Guard, A.R.E. Z-series Topper, BedRug, Bosch Icon Wipers, ScanguageII
ECO-3, Ingen Powerflow CAI, Poweraid TBS, Magnaflow High-Flow Cats, ZOOMERS Dual Out w/ Cannon Tips, PRG Street Traction Bars, Radflow 2" Coilovers, DR Shocks, TIMBREN SES, Stillen f/r sway bars & diff. cover; Royal Purple
* UpRev Tuned @ 93 *
audio: P-Dizzle / tech12volt Awesome Audio
pics: http://www.cardomain.com/ride/2576935
SirStrider is offline   Reply With Quote
Old 01-19-2007, 07:25 PM   #30 (permalink)
blueskys's Avatar
I also have a heavy ARE shell on my KC Titan. I installed the RM active suspension to help with the sag when fully loaded with dive gear. It works. It works well without a compromise in ride quality. The kit preloads your leaf springs and adds capacity to absorb the little bumps without rebound. This makes for a smooth ride. What other kit can you buy that increases capacity and ride quality?
The are no airbags. It is a coil spring that is adjustable to suit your needs.
2007 Pewter Metallic SE King Cab, O/R Wheels and Tires, ARE Z Series Shell, Bilstein 5100s,31,000 miles on Mexican Sonoran back roads in search of the elusive Sonoran lobster.
Helper springs blueskys Titan Towing & Hauling 0 07-04-2006 12:44 PM
Helper Springs and Wrap? Batman229 Titan General Discussion 4 12-31-2005 09:48 AM
Helper springs or ??? stefnch Titan Parts & Accessories 1 04-19-2005 06:26 AM
Hellwig Helper Springs Rotorheader Titan Parts & Accessories 0 04-05-2005 07:33 PM
helper springs grpape Titan Performance Modifications 0 01-22-2005 12:12 PM
