I'll be towing a pop-up camper in a couple months from Houston, TX to Durango, Colorado...Should I drive in 4th gear with Tow-mode on?
That's what I tow all the time, I own a Jayco Baja P/U trailer, it's one of those off-road lifted tent trailers, has 30" tall Dunlop off-road radial tires, even has gas shocks...
I will tow that trailer in 5th(OD) most of the time on flat ground, but my trailer weighs under 3000 lbs, and will manually downshift to 4th on hills.
I also use cruise control all the time, except in the hills, the trans does too much shifting.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
