Old 09-25-2006, 01:39 PM   #1 (permalink)
CMC#64's Avatar
Tow mode/overdrive
Saw a thread a while back where folks stated that you should not tow in overdrive... My owners manual states nothing to that fact, it recommends while climbing to manually downshift it but it does'nt say to stay out of overdrive... I beleive the Tow Mode selection will take care of any overdrive/torque converter lock up issues...
Whats everyone doing??
CMC#64 is offline   Reply With Quote
Old 09-25-2006, 02:10 PM   #2 (permalink)
baseballfanz's Avatar
Re: Tow mode/overdrive
Tow mode only work in 1st to 3rd so in OD it does nothing. Depending on the weight of your load you don't want your truck working hard trying to find the right gear.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 10-02-2006, 10:03 AM   #3 (permalink)
C4RACER's Avatar
I always found it towed better in 4th anyway, and still returned 12-12.5 mpg towing an open car trailer at ~70mph and that was with an Armada which is probably heavier than a Titan. I bet a 4x2 Titan could acheive 13mpg towing a set-up like yours using 4th. Why risk towing in OD?
C4RACER is offline   Reply With Quote
Old 10-02-2006, 10:15 AM   #4 (permalink)
Aquaholic's Avatar
You do know that the Titan has a true 5 speed transmission and has NO overdrive, Right?
2007 White with Charcoal/Titanium interior SE CC 4x4 with off road, tow, SE popular with bench, and utility bed package with sliding bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 325/65/18 Kuhmo Road Venture All terrains, 18x9 Moto Metal 954s, Stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, Rubber bed mat, T Rex Full face grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Infinity Reference 6 1/2's in rear and 6x9's in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 10-02-2006, 09:01 PM   #5 (permalink)
loufish's Avatar
No, it will not. 5th gear is overdrive for this trans, when towing a good sized load on flat roads, or pulling up hill, you have my permission to reach right up to the shift lever an wiggle it right down to 4th gear...
When do you want to take control of your own transmission?
1. When the torque converter will not lock up.
2. When the trans is hunting from one gear to another.
3. If the tranny temps starts to rise.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 10-03-2006, 08:06 PM   #6 (permalink)
Learjet's Avatar
4th gear works great pulling my Travel Trailer. Doesn't downshift going up overpasses and doesn't hunt.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 10-03-2006, 09:50 PM   #7 (permalink)
Smoke05's Avatar
If you have a console shift reread your manual. Mine states to tow in 4th gear. 4th gear locks the converter. Tow/haul subtly changes the shift points.
I think the shift on the column is a bit different.
Smoke05 is offline   Reply With Quote
Old 10-03-2006, 10:06 PM   #8 (permalink)
Carbeaux's Avatar
I don't THINK the tranny itself is any different from console shift to column shift. Still recommends 4th gear tow I'll bet.
Hook 'Em Horns!
Carbeaux is online now   Reply With Quote
Old 10-04-2006, 08:15 AM   #9 (permalink)
Learjet's Avatar
page 9-34 of the 2006 owners manual states not to tow in "overdrive"
Born 5/06
Old 10-04-2006, 08:20 AM   #10 (permalink)
Learjet's Avatar
5th gear in the Titan is an overdrive ratio. Overdrive means a gear that the output of the shaft is faster than the input! Call it 5th or overdrive, it is the same in this case.
4th gear in the Titan is a 1:1 ratio, i.e. if the engine turns 2000 rpm the drive shaft turns 2000 rpm.
Born 5/06
Old 10-04-2006, 09:47 PM   #11 (permalink)
loufish's Avatar
Not by itself, you still need to reach somewhere over 50-55 mph with light throttle.
Born 9/2004
2002 Honda XR650R
Old 10-04-2006, 10:36 PM   #12 (permalink)
RockyMtnMechanic's Avatar
You don't see a big reduction in fuel mileage when towing in 4th?
2004 LE 4X4 Crew
Banks Monster Exhaust
Violant Cold Air intake
TB bypass
RPG Front leveling Kit
Rear air Bags
Big Tow
Tinted windows
Remote start
Chrome tail light covers, tail gate cover
Vent shades
Bug deflector
RockyMtnMechanic is offline   Reply With Quote
Old 10-05-2006, 08:26 AM   #13 (permalink)
Learjet's Avatar
not with a travel trailer.
Now if I was pulling a utility trailer I might use overdrive on the interstate. It is not all about the weight, drag has a lot to do with it and drag with a TT is huge. 4th gives you @ 400 more Rpm's which going 60-65 with a Travel trailer in tow is perfect.
Born 5/06
Old 10-05-2006, 12:19 PM   #14 (permalink)
Are you sure about that page number? 9-34 in My 2006 Titan Manual has instructions about installing the trailer brake controller.
JetDriver is offline   Reply With Quote
Old 10-05-2006, 03:41 PM   #15 (permalink)
Learjet's Avatar
that is the page number on the PDF version I downloaded from Nissan.
here is the copied quote:
"To maintain engine braking efficiency and
electrical charging performance, do not use
overdrive."
It is under trailer towing tips in chapter 9 right after the brake controller info.
I don't think the reason they give is the best reason for using 4th, but it does say it there. Many threads on this subject if you do a search.
Born 5/06
tow mode NOT big tow Frequen.C Titan Towing & Hauling 18 02-07-2006 01:02 PM
Manual does state not to tow in Overdrive. Mike Up Titan General Discussion 9 05-02-2005 07:32 AM
Blaupunkt Overdrive Series Subwoofer life_is_good Titan General Discussion 3 04-21-2005 05:26 PM
what does 'tow mode' mean for me? stick Titan General Discussion 6 02-05-2005 10:55 AM
XE Tow Mode? TitanDriver Titan General Discussion 26 12-03-2004 07:47 AM
