Old 10-12-2006, 12:11 PM   #1 (permalink)
Reverse Camera License Plate
Is anyone using this and if so, what monitor do you buy for this?
Is it working the way you expected it too? If not, What would you do different for backup camera?
I hookup by myself and use a Hensley hitch, a camera is a must!
Steve
Green Mountain Titan is offline   Reply With Quote
Old 03-06-2007, 08:06 AM   #2 (permalink)
Re: Reverse Camera License Plate
Steve
This may be little late, but I bought one from Wal-Mart for less than $100 made by Roadmaster called the VR3 backup camera system. It bolts to the tag and it's a little more than 1 inch square and about 3\4 inch deep. You just wire the two wires to the backup lights and it RF transmits to the monitor in the front that plugs into the cig. lighter. The camera comes on when you put it into reverse, but it occasionaly picks up some stray RF like the occasional wireless security camera or some oter radio frequency. All in all it still works pretty good.
cpaul is offline   Reply With Quote
Old 03-06-2007, 09:20 AM   #3 (permalink)
ablexus's Avatar
Send a message via AIM to ablexus
How easy would such an item be to steal? Not that I'm interested in unlawfully acquiring one, simply that if I got one, I wouldn't want it to wander off...
Andrew
A.K.A. Whore Without A Cool Whore Name
Here's my truck and an angry little force-fed 4-banger:
12 cylinders, 650 hp, 700 tq. Lamborghini, eat your heart out.
ablexus is offline   Reply With Quote
Old 03-08-2007, 08:06 AM   #4 (permalink)
As easy as it was to put it on, especially if you use the supplied screws/nuts. You can always use special screws (e.g., torx) that require special tools to get them on/off. Problem with Torx is that it's not as uncommon as you think. Google around for security screws.
Idea: use one-way screws. Only way to get it off would be to cut the screw head off. :-)
timid1 is offline   Reply With Quote
Old 03-08-2007, 08:10 PM   #5 (permalink)
It is really easy to make secutity screws. Take an allen head or torx screw, simply find a pop rivet, drill a hole the same size in the socet hole and super glue the rivet stem in. When dry snip off.. You can buy security screw adaptors from harbor freight or the like...
I had a full race bodywork on my road bike (in case I tossed it down the road) and made all the screws secruity...
seanpretty is offline   Reply With Quote
Bull bar / Skid Plate with a license plate? dank78 Titan Parts & Accessories 14 10-17-2006 07:01 PM
License plate? black04titan Titan General Discussion 24 06-27-2006 02:23 PM
Adding a reverse camera jlbutler2879 Titan Visual & Audio Discussion 1 06-07-2006 07:39 AM
Reverse camera installs jlbutler2879 Titan Visual & Audio Discussion 8 05-18-2006 09:17 AM
License Plate vs. Skid Plate problem... DaveS Titan General Discussion 23 11-11-2004 08:31 AM
