Old 10-15-2006, 01:40 PM   #1 (permalink)
fixed problem no rh or lh trailer brake or turn
posted on the 8th about no rh turn or brake lamps on trailer only. well i found the problem for those that may have same problem. on a recall done by dealership before i bought truck on a towing recall they replaced a harness under the driver side dash just above the gas pedal. it consist of 2 fuses lh and rh my rh was blown fixed the problem hope this helps
donlloy is offline   Reply With Quote
Trailer Left Turn Signal/left brake light not working bclmread Titan Towing & Hauling 60 04-06-2008 05:43 AM
no rh brake or turn on small trailer donlloy Titan Towing & Hauling 7 10-16-2006 10:11 AM
Trailer Brake Question/Problem vw1972bugs Titan Towing & Hauling 3 01-14-2005 06:38 PM
Fixed my radio problem static101 Titan General Discussion 17 03-10-2004 05:49 PM
