Old 10-19-2006, 12:18 PM   #1 (permalink)
Which model brake controller should I get?
I'm sure this was discussed before but after a couple hundred searches here for the answer I figured posting the question would be easier.
I have a 2007 Nissan Titan Crew Cab with Tow Package.
I'm buying a 2006 SeaRay Sundeck 240 26 foot boat with tandem axel trailer which has trailer breaks.
Which Break Controller is recommended. I see they cost anywhere from 60 to $120 depending on what you buy but I have no clue what will work the best.
Thanks,
Chris
MrSmoofy is offline   Reply With Quote
Old 10-19-2006, 01:19 PM   #2 (permalink)
krh2's Avatar
Re: Which model brake controller should I get?
I bought the Prodigy controller. Rated as best on the market. You can also buy a Titan wiring harness for around $15 witch makes it plug and play. Works great with my 25' TT. I think I paid around $140 for the unit at a local rv store. I'm sure you can find it cheaper on the net.
http://www.tekonsha.com/prodig.html
krh2 is offline   Reply With Quote
Old 10-19-2006, 01:21 PM   #3 (permalink)
thclimer's Avatar
Chris,
First let me congratulate you on your new purchase. Second I’ll chime in on the Prodigy brake controller and if you buy it from RVWholesalers:
http://rvwholesalers.com/catalog/pro...0&cat=6&page=1
for $99 I believe you get free shipping.
thclimer is offline   Reply With Quote
Old 10-19-2006, 01:31 PM   #4 (permalink)
walleeme's Avatar
I have a prodigy too. Ultimately adjustable and easy to use.
You got electric brakes on your boat trailer? Or do you just want the controller to round out your truck?
walleeme is offline   Reply With Quote
Old 10-19-2006, 01:52 PM   #5 (permalink)
krh2's Avatar
Here's some pics of mine
Bracket
Wiring harness above parking brake
Contoller and Titan harness
Mounted
Old 10-19-2006, 01:53 PM   #6 (permalink)
I was told the trailer comes with electric brakes. It is a Magic Tilt Tadem Trailer TML2460
So I'm just trying to get prepared for it. When we bought the Titan back in Jan we got it with the tow package knowing that one day we would have a boat to tow well that one day is right around the corner now.
Ordering from RVwholesalers would be great and free shipping is great but it's UPS ground and I HATE UPS! They always take 10+ days to deliver anything to me. Fedex ground is always cheaper and faster. Anyways I will need this break controller for when I go pick up the boat in about 6 days.
Seems like everyone talks about the prodigy so it must be the one to get.
Thanks for the replies.
Old 10-19-2006, 02:10 PM   #7 (permalink)
krh2's Avatar
Congrats on the boat purchase. I have a 19' Maxum (3,800) and a 25' Aljo TT (6,000 lbs dry) Tows boat and TT no problem.
Here's a cool site for boat owners, its run by a cop on the Parker strip in Arizona.
http://boatcop.com/smf/index.php
Old 10-19-2006, 10:21 PM   #8 (permalink)
BroncoAZ's Avatar
Prodigy is by far the best. I got mine new in the box off ebay (buy it now) for $77 shipped. I had it in 2 days, priority mail.
Mitch
BroncoAZ is offline   Reply With Quote
Old 10-20-2006, 07:19 AM   #9 (permalink)
Learjet's Avatar
Prodigy...I put mine in front of the right knee, so I could see the read out thru the steering wheel.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is online now   Reply With Quote
Old 10-21-2006, 05:52 PM   #10 (permalink)
titanmike's Avatar
I just got my prodigy the other day. $125 shipped 2nd day air with the nissan wiring harness. i'll look where i got it from in a few.
04 SE KC. BT OR 128,000 miles and going strong. Still on the second set of tires.
06 LE KC. BT 50,000miles. S&B Intake. 22" magnaflow muffler. Bully Dog Power Pup. Truetrac, rear fog lights. 2.5" leveling kit. Air Lift airbags. Back up camera. 18x8.5 Viscera 506's w/ 325-60-18 Nitto Terra Grappler A/T's. Bushwacker fender flares color matched. 6000 hid low beams and fog lights.
titanmike is offline   Reply With Quote
Old 10-23-2006, 07:42 AM   #11 (permalink)
Well thanks for eveyones help but it turns out the breaks are not electric they are surge disc breaks. If this is good or bad I don't know. Good I don't have to buy a break controller so I save about $100 but are surge breaks better worse or the same?
I have a couple other questions now that I've learned more about this boat trailer but it's not on the same topic as the original question but I'll go ahead and ask.
The trailer requires a 2" ball. No problem. The question though is the drop and rise of the receiver I didn't realize there were so many options. I ended up picking up a kit from Walmart for $25 which has the 2" ball a 3 1/4" drop receiver and a lock all in one kit (was a better deal then buying seperatly).
So about the drop I would guess there is no way to really tell until I back the truck up to this trailer as to what amount of drop I need. First I was thinking truck it's up higher need the bigger drop 3 1/4" but then looking at it maybe I don't need 3" maybe 2" or none at all.
Also had to buy a plug converter to convert the round plug on the titant to a 5 wire flat plug (5th wire I'm told is so it knows when he truck is in reverse so it can disengage the brakes)
Thanks for everyones help and input.
Old 10-29-2006, 02:45 PM   #12 (permalink)
Vector's Avatar
Tekonsha Prodigy seems to be the number one trailer brake controller. I have had mine for a couple of years now and it works flawlessly.
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Monochromatic White Front Grill Surround and step rails
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 11-03-2006, 09:16 PM   #13 (permalink)
Supastipa's Avatar
Surge brakes suck...I tow a 24' Mariah boat (6400 lbs wet) The surge brakes are a pain in the butt. I don't think that there is any other way to brake a submersible trailer though...have fun and be safe
Supastipa is online now   Reply With Quote
Break Controller ApoKalypsE Titan Parts & Accessories 17 07-07-2006 05:50 PM
Getting model info kongmen Titan Visual & Audio Discussion 1 08-19-2005 06:48 AM
Anyone know the make & model ... drpeeb Titan Wheels, Tires & Brakes 2 06-13-2005 06:56 PM
Next years model...? Titan78951235789 Titan General Discussion 12 05-09-2004 09:49 AM
k&n air filter model # L.A.FIREMAN Titan Performance Modifications 8 05-01-2004 08:18 PM
