Old 10-21-2006, 11:34 AM   #1 (permalink)
speedfrk's Avatar
Unhappy Another Trailer Lighting Issue
Ok, i have read the other post with trailer lighting problems, but mine is a little different. I have running lights and the right side has turn signals, and brake, but the left side does not. I put a volt meter straight out of the 7 pin at the back of the truck and not getting any readings. I also had blown the 10 amp fuse under the hood for the running lights, after replaced it still no turn signals or brake on the left side, but regained running lights.
I have check every fuse under the hood and in the cab all good.
any help would be appreciated
Thanks
Rob
speedfrk is offline   Reply With Quote
Old 10-21-2006, 12:51 PM   #2 (permalink)
Re: Another Trailer Lighting Issue
nissan replaced a harness under the steering wheel just above the gas pedal it should have two fuses in a white plastic holder lh and rh check those fuses
donlloy is offline   Reply With Quote
Old 10-21-2006, 01:24 PM   #3 (permalink)
speedfrk's Avatar
donlloy,
Thank you very much that fix the problem perfectly, how on earth did you even know that those two fuses where there, i even took it down to my local Nissan dealer and they had no idea how to fix it.
Again Thanks
Robby
Old 10-21-2006, 01:59 PM   #4 (permalink)
baseballfanz's Avatar
Originally Posted by speedfrk
donlloy,
no rh brake or turn on small trailer
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Lighting for the Titan pyromedic Titan General Discussion 0 06-11-2005 08:33 AM
Is this a Horn Issue (First issue for a newbie) lsutyger Titan Problems & Dealer Service 14 10-04-2004 05:39 AM
lighting gtbigup01 Titan Performance Modifications 5 08-15-2004 11:38 AM
