Re: Towing Tips
Get a good brake controller and make sure you have it set up properly.
When setting up a brake controller for the first time, set the gain to 50-60% for starters. Tow the trailer at 20 mph. With your foot on the accelerator going 20, use the manual brake controller override. If skidding occurs, reduce the gain and retry. If braking is inadequate, add gain and retry.
Note: A trailer which has been parked for a while will always be heavy on the braking when you first start up. If you had it properly set up when you parked it don't change it to lower power, as it will shortly warm up, clean itself up, and go back to normal.
on edit: The only true brake controllers are made by Tekonsha and Hayes. All others, (Draw-Tite, Reese, Tap, Jordaon and AccuPower are Timers/Activators, in other words they are delayed reaction
Brake Controller and Timers work differently. Brake controllers, set the gain (amps) according to the weight of the trailer, and the level of braking power used. These "timer" style brake controllers operate in a way which are not capable of responding to the requirements of a panic stop.
2006 Crew Cab 4X4 SE, Galaxy Black, Big Tow, Preferred options package, Extang Freedom tonneau cover, chrome taillight bezels, factory replacement chrome mirror covers, billet grill insert upper and lower, Hunter brush guard, SSC chrome alloys, chrome tailgate handle trim, 8K HID low beams, 30% tint, Motorola HF850 bluetooth, 2.5 " front lift, woodgrain interior kit, Audiovox XM radio
