Old 11-13-2006, 08:56 AM   #1 (permalink)
KERR's Avatar
Send a message via AIM to KERR Send a message via Yahoo to KERR
non factory tow, can it be installed?
So im looking at e bay and there is a crew cab 4x4 titan with out a tow hitch. The only real reason im looking at them is to tow with. So if i buy one can i take it to my local nissan dealer and have them install the hitch and be good to go. The wifes armada came with the tow package and does a grate job at pulling. The only problem is when i need to tow i take her ride and becomes not very friendly...
KERR is offline   Reply With Quote
Old 11-13-2006, 09:26 AM   #2 (permalink)
KERR's Avatar
Re: non factory tow, can it be installed?
never mind i found the answer in another post
Old 11-13-2006, 11:34 AM   #3 (permalink)
Aquaholic's Avatar
Adding a hitch to a SE is 7500 lbs. Adding a hitch to a LE will tow 7200 lbs. If you find one with the tow package it tows 9500.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 11-15-2006, 12:59 AM   #4 (permalink)
SportCoupe's Avatar
OK, the factory tow package consists of the following.
-tow receiver
-lower rear gear ratio
-heavy duty rear springs
-tranny temp gauge
-heavy duty battery
Now, I can see only the rear springs being responsible for the increase from 7500 pounds tow to 9500 pounds tow, nothing else really. Please correct me if I am wrong.
2005 TITAN LE CC
Radiant Silver
51,000 miles
SportCoupe is offline   Reply With Quote
Old 11-15-2006, 01:30 AM   #5 (permalink)
Yahooligan's Avatar
The lower axle ratio as well, the engine has to do less work since the lower ratio increases the torque multiplication. More torque (which is what actually gets you moving) to the wheels for the same amount of work from the engine. Higher gear ratios mean the engine has to work harder to accelerate since the engine will be in each gear longer and until a higher speed.
Think about the difference between starting off from a stop in 2nd gear instead of 1st gear. The difference isn't that great with the axle ratio, but it's the same principle.
Edit: The springs would only change payload capacity, which for towing a 7500lb trailer to a 9500lb trailer would be a difference of ~200lb on the hitch.
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454
Yahooligan is offline   Reply With Quote
Old 11-15-2006, 05:01 AM   #6 (permalink)
BigA's Avatar
-tow receiver
-tranny temp gauge
-heavy duty battery
I didn't know the springs were any differant, the tow also has the bigger mirrors and wireing for trailer brake controller.
2005 Silver KC SE, Popular Package with Captains Chairs, Big Tow, Charcole wheels, OEM Bedliner, Foglights, Bugshield
BigA is online now   Reply With Quote
Old 11-17-2006, 12:40 PM   #7 (permalink)
dank78's Avatar
So just your gear ratio makes a difference of 2000lbs of tow capacity? That doesn't seem right.
"A man is measured by the size of things that anger him."
Mods:
* Volant CAI * 18" Magnaflow muffler * Weathertech ventvisors * 18" KMC XD Diesels (Chrome)
* Scangauge II w/blendmount * Gibson exhaust tip - 45 deg. slash * Toyo Open Country AT's 265/70R18 * Bilstein rear shocks
dank78 is offline   Reply With Quote
Old 11-17-2006, 12:59 PM   #8 (permalink)
Yahooligan's Avatar
Why doesn't it? It allows the truck to tow more weight without working much/any harder because of the torque multiplication.
3.82:1 1st gear X 3.35:1 rear-end = 12.797:1 gear reduction w/ BT.
3.82:1 1st gear X 2.94:1 rear-end = 11.231:1 gear reduction w/o BT.
Say you're putting out 300lb-ft of torque at the crank. With BT you're putting down 3839lb-ft at the wheels. Without it you're putting down 3369lb-ft, a difference of 470lb-ft or 14% more torque with BT. More torque to the wheels means you can get a heavier load going with the same effort as a lighter load with a higher gear ratio, with means less stress on the engine and transmission.
Old 11-18-2006, 08:38 AM   #9 (permalink)
loufish's Avatar
Actually that's about what most trucks see in the difference in rear gears for towing. It's more about the trans, taller gears means more torque the trans handles.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
I self installed the factory XM radio, and love it!!! ninergoose Titan Interior Discussion 3 03-28-2005 04:59 AM
If anyone doesn't want there factory installed sirius tuner PM me! hunka27 Titan General Discussion 2 01-19-2005 08:50 PM
XM Factory Installed In 05? Photo of Ant. Titan Fever Titan General Discussion 3 12-03-2004 08:09 AM
? About The Factory Installed Xm Satellite Radio Deepwater Titan General Discussion 9 11-12-2004 10:58 AM
New Factory Radio Installed Today culbrze Titan General Discussion 4 08-14-2004 10:30 AM
