Old 11-18-2006, 05:05 PM   #1 (permalink)
thebassn8tr's Avatar
My white back up lights don't turn on when my boat is hooked up.
When I have my boat hooked up to my factory hitch and wiring harness the back up lights in the tail lights don't turn on when I go down the boat ramp. When I have nothing plugged in to the factory hitch wire harness the tail light back up lights come on. Is it just me?
thebassn8tr is offline   Reply With Quote
Old 11-21-2006, 07:48 AM   #2 (permalink)
loufish's Avatar
Re: My white back up lights don't turn on when my boat is hooked up.
They don't light up, on the truck? But they do soon as you unhook the trailer harness?
Are you useing the factory 7 pin connector on the truck, and what is the connector type on the trailer?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 11-22-2006, 05:01 PM   #3 (permalink)
They only light up when there is no trailer. I'm using the factory 7 pin. The connector type on the trailer is flat. But I have an adapter that goes from the flat plug to a circle plug that fits on the truck. Why?
Old 11-27-2006, 12:42 PM   #4 (permalink)
Although it is a 7 pin connector, the trailer end has only 4 pins.
Old 12-03-2006, 11:15 AM   #5 (permalink)
BobNYC's Avatar
the 4 pin connector doesn't support back-up lights. It only handles running lights (taillights), brake lights, left & right turn signals.
BTW...I always disconnect the trailer lights when I back down the boat ramp. Most of the other boat owners I know do also.
'07 SE KC Titan, Tow, Utility Bed, Off Road and Preferred packages, Majestic Blue
BobNYC is offline   Reply With Quote
Old 12-03-2006, 03:05 PM   #6 (permalink)
That would be what the problem is. Thanks.
Old 12-06-2006, 08:17 AM   #7 (permalink)
Grizzlymudder's Avatar
but your trucks back-up lights should still come on...
Grizzlymudder is offline   Reply With Quote
Back up lights TitanicCaptain Titan Parts & Accessories 15 11-18-2006 05:11 PM
White Titan with Projector lights webslinger1977 Titan Parts & Accessories 19 05-17-2006 10:06 AM
running lights on boat trailer bellpac Titan General Discussion 4 04-18-2005 06:26 PM
Lights turn off while turning brights on/off tobz Titan General Discussion 14 01-03-2005 01:46 PM
Gauge lights not lightning up when i turn on lights??? ChadEberly Titan Problems & Dealer Service 4 11-15-2004 11:17 AM
