Old 12-01-2006, 09:57 AM   #1 (permalink)
BroncoAZ's Avatar
2 degree advance, effects on towing?
I've read thread after thread in the performance forum about the 2 degree timing advance adding performance. I would like the increased performance, but not if it will negatively effect the towing performance. I'm concerned that the advance could cause the truck to ping under heavy load (like dragging 9K up a mountain pass at 7,000 ft). Does anyone that tows frequently have the advance? If so, any thoughts?
Thanks,
Mitch
BroncoAZ is offline   Reply With Quote
Old 12-01-2006, 10:02 AM   #2 (permalink)
onehundredk's Avatar
Re: 2 degree advance, effects on towing?
from what i understand its just ignition timing, giving more umph when you press on the trottle...shouldnt effect towing at all. ECU remapping/chips/dynotunes will...most of your performance should be exhaust, intake, and headers
onehundredk is offline   Reply With Quote
Old 12-01-2006, 10:12 AM   #3 (permalink)
If it starts knocking, I think the ECU will retard the timing.
2 Degree Advance? blacknwhite71 Titan Performance Modifications 25 12-03-2006 01:56 PM
Anyone out there got the 2 degree advance in the Bmaez Titan Performance Modifications 5 11-14-2006 04:52 AM
+2 Degree Advance Timing at Old Town meet on Oct. 28 Thrust_Titan Florida Forum 9 10-27-2006 04:23 AM
2 degree timing advance titanrookie Titan General Discussion 2 07-17-2006 12:44 PM
