Old 12-01-2006, 01:03 PM   #1 (permalink)
Learjet's Avatar
Actual weight of my Truck and Travel Trailer
Ok, so it only took a year but finally weighted my Titan and TT.
Truck with me and full fuel: Steer axle 2960
Drive axle 2440
Total 5400
Truck with me,full fuel, trailer full water (water tank is between tongue and axle on trailer)
Steer axle 2920 (max front 3377)
Drive axle 3180 (max rear 3800)
Trailer axles 4960
Gross 11060 (CGRWV 14650)
This is after I raised the bars one hole. The bars a really tight now. I figured the total trailer weight is 5660 and 700 of that is tongue weight (max is 940). My truck with me, full water and the trailer weights 6100 lbs (GVWR 6422) Looks like 322 for wife and what ever else ( this is the only number I might be over a couple of hundred pounds on some occasions)
When I raised the bar one notch, It shifted 200 lbs to the front axle and made the front axle very close to the unloaded weight (see numbers above. I can't imagine more on these bars. I have the Equalizer brand with 1000 lb bars.
It drives and handles great, What do you think?
2006 Nissan Titan CC with tow package
Equalizer
Prodigy brake controller
2006 KZ Frontier 2303P-F
Yamaha EF2600c Tri-Fuel Gen.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 12-01-2006, 01:37 PM   #2 (permalink)
Carbeaux's Avatar
Re: Actual weight of my Truck and Travel Trailer
You're lighter on the front loaded than when unloaded. You want to transfer it back to the front. Move it up the extra notch you mention.
Hook 'Em Horns!
- Frank Zappa
Old 12-01-2006, 01:46 PM   #3 (permalink)
Learjet's Avatar
that is the weight after the extra notch. It would be really really tight if I go anymore? I been driving it around a year with it a notch lower and felt ok. I am goind to try this setup this weekend.
I guess what I am asking is... if it handles fine,the weight is bascially unchanged on the front axle from loaded to unloaded then I should be ok?
I think the equalizer brand hitch does a better job at the sway control the weight distributing.
Born 5/06
Old 12-01-2006, 02:25 PM   #4 (permalink)
Quartz's Avatar
I gotta agree with Carbeaux on this one. The front axle seems a little light. Does it try to wander on the highway, wallow through turns in town, or wander on moderately windy days?
Old 12-03-2006, 08:36 AM   #5 (permalink)
Here are my numbers on my Ttian and Outback 28rsds TT fully loaded down the road. 2 adults and 3 kids 5 bikes and fire wood. The only thing I will not haul is water in the TT.
Steer-3,220
Drive-3,880
Trailer 5,880
Total-12,980
Johnny
Johnny is offline   Reply With Quote
Old 12-03-2006, 08:41 AM   #6 (permalink)
Carbeaux's Avatar
And I'd say those are good numbers. I'm still thinking that somehow, Learjet needs to transfer a little more weight to his steer wheels. Maybe an angle adjustment of the head?
Hook 'Em Horns!
- Frank Zappa
Old 12-03-2006, 09:04 AM   #7 (permalink)
I forgot to add I do have a Henley arrow hitch with 1400# bars.
Old 12-03-2006, 02:57 PM   #8 (permalink)
Learjet's Avatar
I have 6 washers on the Equalizer brand head and the bars are really tight and angled up slightly.
I guess I need to see how many washers I can add.
Born 5/06
Old 12-03-2006, 07:22 PM   #9 (permalink)
Carbeaux's Avatar
The bars should be level if possible, so if you can and the head's rated for another washer, then I'd try that. That might be just the ticket.
Hook 'Em Horns!
- Frank Zappa
Old 12-04-2006, 12:34 PM   #10 (permalink)
Steamguy's Avatar
Trailer axles 4960
This is after I raised the bars one hole. ... When I raised the bar one notch, It shifted 200 lbs to the front axle and made the front axle very close to the unloaded weight (see numbers above. I can't imagine more on these bars. I have the Equalizer brand with 1000 lb bars.
The classic way to set up is to try to have the weight on the axles within 75# of each other. This is for a half-ton truck with a gas engine. This will "plant" the truck firmly on the pavement both front and back, and make everything much less suseptible to wind and quick maneuvers.
When I set up my truck, I ended up having to take up on the equalizer bars by two links versus that of my diesel truck. Of course the diesel was a one-ton truck. And I also have 1,000# bars.
It doesn't matter too much where the bars are for level, as long as they're not real far up or down. They need the space to flex as you travel over bumps and such. Try for something like straight across when you're hooked up and cinched up.
Hope this helps.
Steamguy
Finally found an appropriate sig pic. It's good at least through August...
Old 12-16-2006, 08:13 PM   #11 (permalink)
Mine came in at 14,900 before my wife got in and the rest of her junk. She is only 113 but her junk is a lot more.
2006 Titan LE CC BT 4X4
Offroad pkg
DVD
Nav
Prodigy
WD hitch
Sway control
AEM brute force CAI
Firestone Air Bags
Magnaflow Cat Back
Fire and Ice LED
adamsrk is offline   Reply With Quote
Questions on new Travel Trailer Ramon Titan Towing & Hauling 5 06-24-2006 07:38 PM
Anyone ever lift their travel trailer? CoachBoone Titan Towing & Hauling 16 06-05-2006 12:59 PM
Online Travel Trailer & Tow Vehicle Weight Calculator Masa Titan Towing & Hauling 2 05-04-2006 07:41 AM
Actual Towing Capacity on Door Sticker vs. Actual Trailer Weight LynchTR Titan General Discussion 22 08-27-2004 03:02 PM
Need Travel Trailer Advice.... JetTech Off-Topic Discussion 6 05-23-2004 10:40 PM
