Old 12-06-2006, 07:51 AM   #1 (permalink)
dank78's Avatar
Capacities using front tow hooks?
I know I just was looking at a topic concerning this yesterday, but for the life of me, I can't find it again. Does anyone know which thread this was?
On a side note, what's the best way to say pull someone out of a snowbank or ditch or something using your hitch. Again a while back someone had a thread with pics of the right way to do this. Thanks...
"If idiots grew on trees, this place would be a freakin orchard!"
Mods:
* Volant CAI * 18" Magnaflow muffler * Weathertech ventvisors * 18" KMC XD Diesels (Chrome)
* Scangauge II w/blendmount * Gibson exhaust tip - 45 deg. slash * Toyo Open Country AT's 265/70R18 * Bilstein rear shocks
dank78 is online now   Reply With Quote
Old 12-06-2006, 08:00 AM   #2 (permalink)
gixxer0.6g's Avatar
Re: Capacities using front tow hooks?
I'd say hook some straps/chains to that area where you'd attach your safety chains on your hitch and pull away. But if you've got the option, use those tow hooks because they never get any lovin and that's what they're there for. As for capacity of them, I'm guessing they'll pull quite a bit. Enough that you should worry more about the straps/chains then the actual hooks.
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
gixxer0.6g is offline   Reply With Quote
Old 12-06-2006, 08:05 AM   #3 (permalink)
dank78's Avatar
Well, the reason I ask is because whatever I was reading yesterday suggested that you didn't want to pull too much with the front hooks because you'd be in reverse and it would put too much stress on your differential. Any truth to this?
Mods:
Old 12-06-2006, 08:08 AM   #4 (permalink)
Yes, do not pull in reverse as you are loading the wrong side of the gear teeth in the differential. A couple of guys here have fragged their front diffs doing this.
Old 12-06-2006, 08:08 AM   #5 (permalink)
gixxer0.6g's Avatar
If I remember right, you've got the most umph in reverse so I'd say you'd be safer tuggin in reverse then in 1st gear but I'm no expert. What do you plan on pulling? If it's another truck I'd say you'd be fine, if it's this(see pic) you might struggle.
~edit...told you I was no expert. Listen to above said, he's an expert
05 4x4 SE~
Performance Mods:
Exterior Mods:
Old 12-06-2006, 08:16 AM   #6 (permalink)
Carbeaux's Avatar
I'm not sure I'd try to hang my truck by them, but they should be sufficiently strong to get you towed out of anything you might get stuck in.
Hook 'Em Horns!
- Frank Zappa
Old 12-06-2006, 08:43 AM   #7 (permalink)
Maybe a junk yard shade tree wannabe would be better description of my experience (although I did have a class that covered gears in college a zillion years ago). Check out Figures 1, 29 and 30 at the link below. If you pull in reverse, you are heavily loading the coast side of the ring gear teeth, which has a smaller tooth contact area. Note also the different angles of the coast and drive sides of the teeth.
http://www.pirate4x4.com/articles/te...sta/Gear_Setup
Old 12-06-2006, 05:44 PM   #8 (permalink)
TitanBlue's Avatar
So it is this:
Get yourself pulled out by your tow hooks.
Do not pull out somebody else with your tow hooks.
Good info bestatchess, never knew that. Should have though.
Outstanding article.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 12-06-2006, 05:48 PM   #9 (permalink)
The hooks are there so someone can pull you out. your hitch is made for pulling. Use it! Never pull with the hooks!
Old 12-06-2006, 05:55 PM   #10 (permalink)
crashgordon73's Avatar
Nice to know. Great link
crashgordon73 is offline   Reply With Quote
Old 12-06-2006, 06:01 PM   #11 (permalink)
redneckpapa1996's Avatar
If you have 4 wheel drive and it is locked in, can you pull with the tow hooks ?????
...................................BEERWHORE™.....................................
"THIS TRUCK IS AWESOME" !!!!!!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White (THE BEAST)!!!!
2* advance, Volant CAI, TBS, Flowmaster 40 series w/4" duel tips, Bilsteins, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights
redneckpapa1996 is online now   Reply With Quote
Old 12-06-2006, 06:03 PM   #12 (permalink)
Yup!!! Just make sure you have a dust pan to scrap up all the front differential pieces when it pops!!
Old 12-06-2006, 06:06 PM   #13 (permalink)
Good answer, Thanks !!!!!
Old 12-06-2006, 07:09 PM   #14 (permalink)
loufish's Avatar
I carry a 30' snatch strap with me at all times, I put one of the sewn loops into the receiver and then put the hitch pin thru it.
This is about a strong of a pull you can get on just about any truck.
And yes, one more vote for the tow hooks for someone pulling my truck out..
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 12-06-2006, 07:39 PM   #15 (permalink)
TitanBlue's Avatar
Common as dirt idea there, shame I've never thought of that! That's outstanding. Now I'll have to go buy a strap just so I can do that some day.
Born June 12, 2006
WTB: Front Tow Hooks TypeSH Buy/Sell 1 11-09-2004 10:11 PM
Tow Hooks in the front? cliffhanger Titan General Discussion 7 10-03-2004 07:13 AM
Wanted: Front tow hooks Slickshoes Buy/Sell 6 09-29-2004 05:36 PM
Front hooks? surge Titan Parts & Accessories 9 08-02-2004 06:30 PM
Daystar 2.5" front lift/ Fact. Front Skid plate w/ tow hooks PigPen Buy/Sell 0 04-20-2004 03:21 PM
We operate more than 100 automotive forums where our users consult peers for shopping infor
