Old 10-17-2006, 03:54 PM   #1 (permalink)
Problem with trailer lights
I have a little problem, when i purchased my titan it did not have a tow package. So I bought one off ebay, it came with the wire harness that plugs right in the socket under the bed.
The problem I am having is my parking lights on the trailer do not work when the trailer is plugged in. The brake lights and directionals work fine. I know its not a problem with the trailer because I tested it with another truck and they worked fine. Any suggestions?
Bpelkie is offline   Reply With Quote
Old 10-17-2006, 05:54 PM   #2 (permalink)
Sticky Teflon's Avatar
Re: Problem with trailer lights
I have the exact opposite problem. I had the dealer install a tow pkg as part of my 4x4 deal. Only my running lights work and not the brakes or signals???? I知 taking it to the dealer on Friday to find out why. if i get any good info I値l pass it along.
I do believe though that there are supposed to be two relays in the rear when a tow is added. i have a feeling I知 missing one or both and you probably are also.
Later,
Sean
06' Se KC
4x4, Tow
Galaxy Black
Ares bull bar
BakFlip Tonneau... on the way
Leveling Kit .........on the way
In search of the perfect (low cost) Tire/Wheel combo
Sticky Teflon is offline   Reply With Quote
Old 10-17-2006, 06:16 PM   #3 (permalink)
Titan06RX1's Avatar
Send a message via ICQ to Titan06RX1
Later,
Sean
I think the relays go under the dash and under the hood. Been 8 months since i had my fatory hitch and wiring installed so i cant remember for sure.
Kenwood DNX7100 full system 1800 watts, Kenwood Rear View Camera, Bull Bar, Hella 500 Off Road Lights, Xtang Tonneau Cover, Motorola Blue Tooth, 2* Advanced Timing, AEM Brute Force Cold Air Intake, 12mm Oil Vent, 2"Leveling Kit, BF Goodrich Radial AT's 285/65/18, Nissan Hitch, Big Tow mirrors, Nissan Keyless Entry Keypad, Cobra Radar Detection
Titan06RX1 is offline   Reply With Quote
Old 10-17-2006, 06:30 PM   #4 (permalink)
same thing happened here and it was a fuse...blew upon initial connection...now totally fine..but had to replace it
CdnTitan LE 4x4 is offline   Reply With Quote
Old 12-21-2006, 07:28 PM   #5 (permalink)
same problem here, and I have BT! We popped the hood and guess what, NO RELAYS. I am going tomorrow and the dealer will install them
Cutler is offline   Reply With Quote
Old 01-02-2007, 08:41 AM   #6 (permalink)
Do you have to purchase the relays?
Ayjay'sTitan is offline   Reply With Quote
Old 01-02-2007, 08:47 AM   #7 (permalink)
baseballfanz's Avatar
If you have the BT Package or purchase the hitch from the dealer it should have came with the relays, if you got an aftermarket hitch than you need to buy the relay from the dealer.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 01-02-2007, 09:24 AM   #8 (permalink)
Do you know how much they cost? Thanks
Old 01-02-2007, 09:58 AM   #9 (permalink)
Brake Relay $18 - Trailer Light Relay $26
Old 01-02-2007, 10:49 AM   #10 (permalink)
I need both relays? Do you know where they install to?
Trailer Running Lights tshank Titan Problems & Dealer Service 8 08-01-2008 12:13 AM
Trailer lights Jarlow273 Titan Towing & Hauling 10 06-20-2007 09:47 AM
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 05:33 PM
trailer lights for a 4x2 SKEET Titan Towing & Hauling 2 12-21-2005 08:48 PM
Trailer lights cougar Titan Towing & Hauling 7 07-11-2004 09:48 AM
