Old 01-05-2007, 09:56 AM   #1 (permalink)
Tow Relays for 2006
I have a 2006 LE that I am installing a trailer hitch and harness on. I installed everything and have the Blue and Brown relays. I went to plug them in and there are three empty relay spots, one for the brown (Trailer #2) and then there are two that say Trailer Signal L and Trailer Signal R. Do I need two of the blue relays or are there different relays that go in there?
halemeister is offline   Reply With Quote
Old 01-05-2007, 09:58 AM   #2 (permalink)
baseballfanz's Avatar
Re: Tow Relays for 2006
For 06 you need 3 relays total.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 01-05-2007, 07:11 PM   #3 (permalink)
Are the two turn signal relays the same? Or is there a different relay for the third?
Old 01-05-2007, 08:53 PM   #4 (permalink)
Dorsey's Avatar
You need two blues for the 06. Same part number L and R.
Dorsey is offline   Reply With Quote
Where do i install tow relays? Ayjay'sTitan Titan Towing & Hauling 11 01-12-2007 07:09 PM
Relays for 06 topherdbu Titan Towing & Hauling 2 09-01-2006 01:48 PM
2006 Titan hitch relays thabeast Titan General Discussion 5 06-19-2006 01:19 PM
Towing Relays aero320 Titan General Discussion 3 03-07-2005 07:13 PM
