The boat doesn't weigh 3000# but, when I go crawfishing I can put 1000-1500# of crawfish in boat. I will ask when I go in for service, I have a couple of issues with truck only 29000 miles so it,s still under warranty.
ALL Titans have a Tow mode button (I THINK). That does not mean you have the Tow package though..You'll need to see if you have the HD battery, big tow mirrors, tranny temp gauge, and receiver hitch..none of which your truck has, so you don't have the big tow package! you can still tow like 7400 pounds I think
May sound unrelated but I think its relevant. My work truck is a chevy 1500 it does not have a tow package (can only tow 6400#'s) but it does have a Tow/Haul switch. I usually use it when I'm going through the mountains.
06' FFV Galaxy SE CC, red/silver Hand painted pin stripes, Popular PKG w/power captains, Tow/Trac Pkg, Utility Bed, OEM Spray on liner, bed divider, bed tray, OEM Step Rails, OEM Soft Tonneau, Airbox Mod.
The dealer can remove the hitch, and maybe swap mirrors, but the trans guage will stay.
I'm pretty sure all the models(at least SE & LE) have the Tow Mode feature.
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
my XE has a tow mode button also so I guess they all do. and I don't have a tow package.
