Which one should I get? The Airlift bags require the frame to be drilled. Will this void my warranty? My truck is not lifted but sags really bad when towing a toy hauler.
Give me the pros and cons of each. Thanks
__________________ 2006 4X4 Titan Crew SE Off-Road
I have the airlift bags with the compressor. I did not have to drill my frame... the ride is a much better with the airlift bags versus Firestone. They both will work it's just your preference.
I really like mine and it was a good modification because my trailer is approximately 8000 pounds
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!! My Train Horn <-- Listen
Can you level on the go, and can you inflate tires with that compressor? My truck's rear suspension handles my 900lbs + tongue weight good, but I want to do a leveling kit so I am considering air bags.
2006 CC 4x4 Radiant Silver: Offroad Package, Tow Package
Current Mods: Glasspack muffler, Helix TB, True Flow Air Filter, Air Box Mod, Airlift Air Bags, 35x12.50x17 Big O XT LT tires, 2º Advance, 2.5" Racerunner Coilovers, Deaver MiniPack, Rear Bilstein Shocks, PRG Shackles
Wish List:PRG UCA, PRG Traction Bars, Upgrade Stock sound system
2005 trx400ex: tcs Front Shocks
2001 xr650r: Tag Handlebars w/Bark Busters, Uncorked, Glass Lens Headlight, Precision Concepts Revalve, smartperformanceinc 215/VM2-K5 fork oil.
2000 yz426f: stock
I installed the Firestone air springs on my Titan. The installation was straightforward and did not require any drilling, other than where you want to mount your valve stems.
I opted not to get a compressor with my system since I have a large one at my house and I figured if I was out driving and needed to inflate more I could use a gas station’s air fill station. If I didn’t have the compressor at home I may have opted for the onboard compressor.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
i have the airlift for over 2yrs now, awesome!!!!i drilled throught the frame, no big deal, firestone from what prg tells me has a stiffer ride compared to my airlift....
Did you weld the brackets on? How are they secured?
looks like I'll have to take some pictures and show you. It was really simple install took about one hour per side. and that included the compressor and airline installation
2005 CC LE
Yes I can level on the go. With the compressor installed its very small and fits underneath one of the back seats on the hump so you don't even see it. The wiring was really easy because in the center console, where I mounted the air gauge is an accessory controlled 12 volt jack.
I'm going to have to check the install because I don't remember drilling but it has been over a year.
2005 CC LE
I just don't want to void my warranty by drilling holes in my frame.
For the airlift bags you just pump them down to about 10 psi, then the rides not affected as far as I could tell... well may be improved a little.
I live in San Diego and sometimes have to drive through Los Angeles. Let me tell you that the ride is greatly improved especially on the 10 freeway when towing! As far as leveling and sway control you can really tell its a huge difference.
2005 CC LE
I will not install the compressor, just the airbags. If the frame does not have to be drilled for installation, I will order the Airlifts right now. I just do not want to void my warranty.
I keep mine at 10 psi also for everyday driving; the manufacture doesn’t want you to ride them empty. At 10 psi I practically don't even know they are there.
I have had them as high as 40 psi when towing my equipment trailer and tractor, maybe its overkill considering I also have an Equalizer hitch with that setup. But, I also like the fact that I can load about 700 pounds of ready-mix cement into my bed and my rear end doesn’t sag.
Equalizer Hitch
Scan Gauge II
A.R.E. Z-Series Cap
I got the firestone with the onboard compressor, and I don't notice any difference in the ride with the bags at 10 psi. Installation was simple I put the compressor under the hood out of the weather. They work great and haven't had any issues with them, highly recommend.
I had the Airlifts on my F-150, and have the Firestones on my Titan. The Firestones are stiffer than the Airlifts with the same pressure, so I just don't use as much pressure as before. With my travel trailer, I would use about 60-70 psi with the Ford, but now only run 30-40 with the Titan. I liked the no drill install.
__________________ 04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
