Old 02-08-2007, 08:25 AM   #1 (permalink)
trailer rt turnn signal inop
?'s for those who have a travel trailer, my rt side turn light does not work, but the rt side brake lt works and also when it tuen my lts on my truck the rt side lts up, what could be wrong?
thanks!!!!
mytitan is offline   Reply With Quote
Old 02-08-2007, 08:45 AM   #2 (permalink)
Re: trailer rt turnn signal inop
its probably a burned out bulb they have two filiments & one is probably burned out
todd128 is offline   Reply With Quote
Old 02-08-2007, 09:23 AM   #3 (permalink)
no thats not it, i switched the left bulb to the rt side and still didnt work....
Old 02-08-2007, 09:30 AM   #4 (permalink)
If you had the BCM harness TSB performed, I think there might be some fuses in the added harness segment under the dash. Also, I assume you have already checked all the fuses in the boxes under the hood.
Old 02-10-2007, 02:34 PM   #5 (permalink)
dlgrice's Avatar
my trailer hooks up with 6 pin connector and the right side doesnt work but left does also for some reason my trailer brakes are locking up after i move about 4 feet does any one else have this problem ????????
dlgrice is offline   Reply With Quote
Old 02-16-2007, 04:21 PM   #6 (permalink)
John S's Avatar
Most likely the wiring... suggest you test the wires to see if you have any current.
2005 S/C Elise
2006 Titan SE 4x4 Tow vehicle
2003 350Z Trackcar - RIP Buttonwillow
John S is offline   Reply With Quote
Old 02-16-2007, 04:26 PM   #7 (permalink)
baseballfanz's Avatar
I would check your E-brake module
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 02-16-2007, 05:46 PM   #8 (permalink)
cp.16's Avatar
Check your relays under the hood, my did not come with one for some reason and I had a simalar problem with the lights..
cp.16 is offline   Reply With Quote
Old 02-25-2007, 01:23 PM   #9 (permalink)
there is a recall on the wireing hitch i had my truck done and so far so good
herman is offline   Reply With Quote
Old 02-25-2007, 02:51 PM   #10 (permalink)
dawgs77's Avatar
You know...I have a problem right now on my Travel Trailer. My right turn signal works until I turn the parking lights on ......then everything works BUT the right burn signal.....
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
dawgs77 is offline   Reply With Quote
Trailer Left Turn Signal/left brake light not working bclmread Titan Towing & Hauling 66 01-06-2009 04:40 PM
12 volt power point inop ucf_motorcycle Titan Problems & Dealer Service 16 08-14-2007 11:01 AM
Take truck to the dealer, and now stereo inop Foglght Titan Visual & Audio Discussion 3 01-21-2007 04:26 PM
Cruise Control inop after distant drive matrixticity Titan Problems & Dealer Service 8 01-15-2007 07:40 PM
air bag system inop CHEK6 Titan Problems & Dealer Service 13 06-06-2004 08:42 PM
