Old 04-22-2007, 09:57 PM   #61 (permalink)
loufish's Avatar
Re: Big Tow towing vs. non-big tow
I hope you replace the ST tires on the trailer, if you have them, which are only rated for 65 mph.
Oh contra...My trailer is "special" it's factory lifted, has gas shocks and...LT tires 30" tall!
No real speed limits....
That being said, I've towed at 90 mph while kind of playing around, but not for any length of time. I'm usually in the 65-70 mph zone.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-23-2007, 09:15 AM   #62 (permalink)
catitanfan's Avatar
Glad I found this site before purchasing my titan Saturday. After reading the info here I decided the tow package was a must. Thanks for the great info guys. I purchased an 07 SE with tow package and like it a lot.
catitanfan is offline   Reply With Quote
Old 04-23-2007, 02:18 PM   #63 (permalink)
StuntDriver06's Avatar
Originally Posted by myogeek
I have read through this forum and seen that a truck requires the BT package to have the lower gear available. I purchased an '07 Crew Cab 4x4 OR and it came with the same gear offered in the tow package. This is part of the OR package. Not sure if this was a change from previous years. To my surprise, it also came with the heavy duty battery (710 CCA instead of the 650). If my truck also has the trans cooler, then I theoretically have full towing capacity minus trans temp visibility.
Taking additional advice from here, I purchased an after market hitch (hidden hitch 70530) from etrailer and the wiring package (30608). My wiring package came with all 3 relays so I did not have to buy the 3rd one from the dealership. Total spent with free shipping was $190. Installed it myself without a problem. I did have to buy a couple of screws from Home Depot to mount it to the underside of the bumper though.
Thanks for all of the good info
what are you referring to here, in the bold... if you are talking about the hitch mount bolts, make sure the ones you purchased are as strong or stronger thatn the ones that come with the factory hitch....
Truck: 2007 Smoke KC SE 4WD OR/BT, pop. package w/buckets
Born: 11/2006
Mine: 11/30/2006
Click For Mods
Click For Exhaust and Other Videos
1/4 Mile Best: 14.6@92.03
1/8 Mile Best: 9.3@73.36
StuntDriver06 is offline   Reply With Quote
Old 04-24-2007, 08:50 AM   #64 (permalink)
myogeek's Avatar
My fault for not explaining this install completely. The hitch did come with 6 high strength bolts that were used to mount it to the pre-tapped holes in the frame. The wiring kit did not come with any bolts/screws to mount it to the underside of the bumper. I had to go out and purchase #10 x 3/4 self tapping metal screws from Home Depot to attach the wiring bracket to my bumper. Sorry for the confusion.
Tip for install of the bracket - measure twice and drill once. Position your bracket in such a way that will allow clearance for the 7-way socket door to open all the way and also enough clearance behind the bracket to allow the bulky wiring connection to fit. This will take some time to measure and test before the final drilling. Take your time. I have two sets of holes in my bumper due to my lack of patience.
myogeek is offline   Reply With Quote
Old 05-03-2007, 02:35 PM   #65 (permalink)
How hard (possible) and expensive is it to change the gear ratios in a non-big tow model Titan?
Titan_Love is offline   Reply With Quote
Old 05-08-2007, 05:38 PM   #66 (permalink)
same question, cant you get the big tow rear 3rd member if you have 2wd, and dont happen to have the tow packege, i know it wont have mirrors and trans temp guage and battery, but the gear ratio is what most of us want.
cnielsen4130 is offline   Reply With Quote
Old 05-08-2007, 05:52 PM   #67 (permalink)
ptgarcia's Avatar
If you can still get the offroad package on a 2wd then the answer is yes. Otherwise, no, you can't.
Pauly
Old 05-09-2007, 04:37 PM   #68 (permalink)
whats the problem with finding someone with a tow package third member, and swapping it out with your non tow package third member? i dont see the problem?
Old 05-09-2007, 04:51 PM   #69 (permalink)
ptgarcia's Avatar
Well you can do anything if you have enough time and money.
Pauly
Old 05-10-2007, 02:33 PM   #70 (permalink)
I learned a few trucks back not to go without the tow package. Like one responder wrote you will always get your money back. I never heard one person ever regret it.
Bob
Bassin Bob is offline   Reply With Quote
Old 05-03-2009, 08:57 PM   #71 (permalink)
Great Information here, thank you. Newbie question.
I will be towing 8000 pounds
I have the 2004 L without the tow package. I have upgraded the shocks, tires rims, added an aluminum finned rear diff cover with synthetic, added an aluminum finned (finned for cooling) large tranny pan that is significantly larger and offers additional fluid capacity - synthetic only in there.
I suspect I need the big tow equivalent tow gears - QUESTION: I live in southern cally (OC), where do you recommend I take the truck to do the gearing upgrade? How much should this cost? Any other recommendations on what I can do to upgrade the truck to enable the truck to safely pull that kind of weight?
Thank you all
(Sidenote - I have been told by a reliable resource that there really is no need to do the upgrades.... I was told that the tranny is over-designed by Nissan and close to bullet proof. That said, I still plan to upgrade to be safe)
Socaloffshore is offline   Reply With Quote
Old 05-03-2009, 09:01 PM   #72 (permalink)
mjw357's Avatar
Originally Posted by Socaloffshore View Post
QUESTION: I live in southern cally (OC), where do you recommend I take the truck to do the gearing upgrade? Any other recommendations on what I can do to upgrade to enable the truck to safely pull that kind of weight?
Thank you all
Do a search on here for "hoopers" that's where you want to go on the left coast for gears.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 05-04-2009, 10:05 AM   #73 (permalink)
Let me do a quick check here. My impression is that if you have a "little tow" Dana 44 (2004 Titan XE) like me, you can do a straight swap in with the "big tow" ring and pinion gears... and have the dealer reflash the ECU. I'm guessing the 3.73 gears are a custom job by a place like Hoopers.
Hampstead38 is offline   Reply With Quote
Old 05-04-2009, 10:36 AM   #74 (permalink)
Banned
I have the Big Tow package too!!!! lol
SiMpLyMoDiFiEd is offline   Reply With Quote
Old 05-04-2009, 11:05 AM   #75 (permalink)
mjw357's Avatar
Originally Posted by Justintoxicated View Post
The larger battery is still a POS :P but at least its a better POS. Mine lastedme 2 years and is still going but after it leaked I decided to change it.
I have the BT and ave never used it. I bougt my truck to possibly pull a trailer but my Dad picked up a 3500 dodge a month later and I have never eve bothered with the titan since it's his trailer, and the dodge is better for towing anyways.
So All I get is Less MPG I get about 14-15mpg freeway with BT and 4x4
Looks like you got the OR package too, so you would have the 3.36 gears either way.
EDIT: Wow this thread is kinda old.
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 07:48 AM
Towing Big without Big Tow nitty Titan Towing & Hauling 24 07-16-2006 04:37 PM
9600 lbs towing! try 17000 lbs towing standingtall Titan Towing & Hauling 1 12-08-2005 05:48 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 02:03 PM
Towing NOVICETOWER Titan Towing & Hauling 57 02-22-2005 05:46 PM
