Old 03-20-2007, 06:11 AM   #1 (permalink)
Install a class IV hitch, myself?
I bought an '07 without the tow package because I wanted the smaller gear...now I'd like to put a class IV hitch on it.
The dealer wants quite a bit for this job ($700) and the hitch is just under $400 on courtesyparts.com. Could I put this thing on myself? Does it bolt up or weld up?
Could I just take it to another shop and have them do it, if so...is it a big enough deal that they'll charge me $300 for labor?
Thanks!
Jason Kelly
Valley Center, KS
kellyj00 is offline   Reply With Quote
Old 03-20-2007, 07:09 AM   #2 (permalink)
vipzach's Avatar
Re: Install a class IV hitch, myself?
Yes, you can put in on yourself. I think the only diiference between the class 3 and class 4 is the WD part that goes into the receiver. It just bolts up there, have some help hold it up and put the bolts in!! Put the relays in(if required) plug in the harness!
vipzach is offline   Reply With Quote
Old 03-20-2007, 07:51 AM   #3 (permalink)
Doom's Titan's Avatar
I found this thread which may help give you some insight. It looks like for significantly less than the Courtesyparts.com price you can get an aftermarket hitch and trailer receptacle and it appears to be a no drilling required, plug and play install. Hope the added info helps.
Adding a non-OEM trailer hitch?
DT
'06 Brawn Red SE. CC/OR/BT Planning on step rails, bull bar/grill guard and a cover sometime down the road.
Doom's Titan is offline   Reply With Quote
Old 03-20-2007, 09:40 AM   #4 (permalink)
Try www.etrailers.com. They had the best pricing when I bought mine. Also, you will need to check the fuse box right behind the battery, there are two relays in there that are needed for the lights to work. I am assuming they are still not putting them on the trucks without big tow, mine didn't have them in 2004.
KYDeepwater is offline   Reply With Quote
Old 03-20-2007, 09:42 AM   #5 (permalink)
Gunner22's Avatar
The OEM hitch will bolt right on to the frame and every titan is prewired so its a very straight forward install. Just find an extra set of hands to help hold the hitch in place and you will be good to go and save ~$300 in labor.
2005 SE KC 4x4: Bedliner and Floor Mats ... thats it.
Add ons: 2* Timing Advance, Extang Black Max Tonneau Cover, OEM Fog Lamp Kit, OEM Hitch Package, Lund Hood Shield, Amsoil EaA104 Air Filter, Earnhardt "Intimidator" License Frame.
Adopted: December 10, 2005
Mileage: 32,445
Gunner22 is offline   Reply With Quote
Old 03-20-2007, 09:46 AM   #6 (permalink)
Gusecu's Avatar
I paid $215.00 for my hitch from my nissan dealer. It came with the (2) fuses and 7 pin harness plug. It took about 20 minutes to bolt up. Make sure you torque down the bolts, and you should be good to go. It was very easy to do.
Gusecu is offline   Reply With Quote
Old 03-21-2007, 05:51 PM   #7 (permalink)
baseballfanz's Avatar
Best to get the factory hitch kit, come with all relays needed.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 03-21-2007, 09:46 PM   #8 (permalink)
Rick Guess's Avatar
on my '05 i put a class 3 on myself it bolt right up and the harness blugs into you adapter (you gotta buy)
but you need the relay from the dealer (or online)
or the breaks wont work
2008 SE KC 4x4 Blizzard White Titan
Tow package and popular package
OEM Bug Deflector
Rick Guess is offline   Reply With Quote
Old 03-22-2007, 08:28 PM   #9 (permalink)
48fan's Avatar
I just added an OEM hitch to my truck last weekend, and I found that it's the easiest and cheapest way to go. The Courtesy Nissan hitch seems cheaper, but the s&h kills.
Cheap aftermarket hitch- $130
3 relays (rh turn, lh turn & brake)- $96 ($32 each)
7 pin Plug - $36
=$261
OEM Hitch kit (receiver, 7 pin plug, and 2 of the 3 realys)- $229
3rd Relay- $32
=$261
and the OEM hitch comes with the mount for your plug welded on.
It took me and my buddy 15 minutes to bolt it on and torque it.
As for the class IV, that's just the class III with a weight distributing hitch instead of a normal ball mount. I picked up the Equal-i-zer on amazon.com for $419, and the shipping and tax are free. That hitch integrates WD with anti-sway in one package.
48fan is offline   Reply With Quote
Old 03-22-2007, 09:52 PM   #10 (permalink)
Deth Blooms's Avatar
I tried to get an OEM hitch from my dealer for my 07 and after waiting a week for them to get it in, they called me and said the hitches arent available for the 07's yet. They have a part #, but Nissan hasnt released them yet. So, they sent me to an aftermarket place and I ended up saving a lot of money. This place charged me 180 installed for the hitch, and my dealer wanted 211 for just the hitch, no labor. The guy that installed it also told me I only needed 2 relays, not 3 like the dealership wanted me to buy
AKA "Whatswithallthiswhorestuff"? Whore
07 Crew Cab SE 4x4 Dark Grey
MB Quart Spkrs, Brute Force CAI, Poweraid TBS, Banks Monster Exhaust, Viper Alarm & remote start.
Coming Soon: Lift kit (PRG 4" PP), 35" tires, Grill Craft front grill (black), and box from tech12volt (on order w/ a Sundown 1500D amp)
Deth Blooms is offline   Reply With Quote
Old 03-23-2007, 07:49 AM   #11 (permalink)
great! thanks fellas.
Jason Kelly
Valley Center, KS
Old 07-21-2007, 12:09 PM   #12 (permalink)
What size bolts did you use to install it? I got my hitch and no bolts.
Doo Dah is offline   Reply With Quote
Old 07-21-2007, 12:39 PM   #13 (permalink)
killcatzforfun's Avatar
take it to uhaul or someone else. i had local company do it for 230 bucks that included everything, even a 2 inch ball with receiver and the wireing for the lights. i think i used tow tite ? idk ill have to go look at my hitch again i took it off from my 05 now its on my 07
07 TITAN CC,O/R,B/T 4X4 SE MAJESTIC BLUE
mods: fram boost air 2 cai.
8000k H.I.D's for low beams and fogs
killcatzforfun is offline   Reply With Quote
Old 07-21-2007, 02:07 PM   #14 (permalink)
I found the hardware. It was in the tube. I did it by myself and learned that you should have your custom exhaust done AFTER you put your hitch in! I had to cut and reweld my pipes so everything fit. Only took an hour though so not bad overall I guess.
Old 07-23-2007, 12:15 PM   #15 (permalink)
Darkblueta's Avatar
Send a message via AIM to Darkblueta
I bought my Hidden Hitch + wiring connectors/relays/etc for 198.xx shipped to my door. Bolted right up in 10 minutes and had it all working and the wires checked with a test light in 30 minutes.
Buying from etrailor.com was a very good experience.
Darkblueta
1998 Trans Am.
Engine, Turbo, intercooled, alky-water injection, 12 bolt, suspension, self tuned and a hell'va lot of fun.
2007 Nissan Titan XE
Daily driver. Beta Testing for Hypertech
Darkblueta is offline   Reply With Quote
U-Haul Hitch question Class 3 vs Class 4 Bentleyguy Titan Towing & Hauling 2 09-11-2006 05:38 PM
WTB Rims/Tires Class III hitch etc.... johnny_rmz Buy/Sell 4 05-01-2006 06:52 PM
What class hitch? BajaV8Titan Titan Towing & Hauling 4 01-15-2006 02:24 PM
class 3 hitch MaxPowers Titan General Discussion 5 03-30-2004 08:43 PM
Class IV hitch questions Titanic_04 Titan Towing & Hauling 9 02-16-2004 06:09 PM
