Old 03-30-2007, 08:18 AM   #1 (permalink)
Towing with O/D and/or Cruise
So I have read several different posts on different sites, but couldn't find real life opinions from Titan owners.
I have a travel trailer that is around 7500# fully loaded.
Living in the midwest, I have a few hills (most would call slight incline or bump). Is it okay to using over drive and/or cruise on the flat highways? I would probably cancel cruise and shift down when on the hills and traffic areas.
Being an 07 CC, how high should I let the tranny gauge get before I change my driving style or pull over?
I believe I heard someone say that it depends on how many miles are on the rear end. i.e. <5000 = 318 degrees, <12000 = 290, etc.
lbffl is offline   Reply With Quote
Old 03-30-2007, 08:24 AM   #2 (permalink)
red_rider_elsinore's Avatar
Re: Towing with O/D and/or Cruise
I use cruise control everytime I am in long stretches of highway. As for 5th gear, you can find out yourself. Next time you're in the road, go into 5th and keep a watchful eye on your tranny guage. If it starts to rise downshift, and if it doesn't its okay. My friend tows a WW fk2100 superlite with a GVWR of 7000+ lbs and he can't pull fifth safely. Anyways, you'd still get better mpg towing in 4th.
2006 CC 4x4 Radiant Silver: Offroad Package, Tow Package
Current Mods: Glasspack muffler, Helix TB, True Flow Air Filter, Air Box Mod, Airlift Air Bags, 35x12.50x17 Big O XT LT tires, 2º Advance, 2.5" Racerunner Coilovers, Deaver MiniPack, Rear Bilstein Shocks, PRG Shackles
Wish List:PRG UCA, PRG Traction Bars, Upgrade Stock sound system
2005 trx400ex: tcs Front Shocks
2001 xr650r: Tag Handlebars w/Bark Busters, Uncorked, Glass Lens Headlight, Precision Concepts Revalve, smartperformanceinc 215/VM2-K5 fork oil.
2000 yz426f: stock
1st ANNUAL GLAMIS TITAN DUNE MEET
red_rider_elsinore is offline   Reply With Quote
Old 03-30-2007, 08:27 AM   #3 (permalink)
vipzach's Avatar
I don't have a tranny temp gauge, can't help there.
I do not tow in O/D ever, nor do I ever turn on cruise control when towing. With the weight you posted, I would not use O/D either.
Like I said though, I don't have tranny temp gauge, so I have never experimented with O/D and the temps.
vipzach is offline   Reply With Quote
Old 03-30-2007, 08:34 AM   #4 (permalink)
BattleWagon's Avatar
First off, I assume you have the tow package since you mention the tranny gauge. That's good for how much you plan on hauling around, however, have you broken in your rear end? The manual states no towing for the first 500 miles you own the truck and for the first 500 miles of towing, to keep things below 50, however the second part can probably be ignored if you have a fair number of miles (say > 3000).
As for driving style, you probably shouldn't base it on the tranny gauge's reading. If it's truely flat and you're doing around 70mph, you can probably get away with 5th gear, but otherwise use 4th, and if things get really steep and/or your tranny gauge does start rising, don't be afraid to use 3rd. Also, be sure to use Tow Mode (holds gears longer).
Cruise control is a person option. I don't use it (I'm a control freak). Happy towing!
BattleWagon is offline   Reply With Quote
Old 03-30-2007, 09:11 AM   #5 (permalink)
HiggySTL's Avatar
I tow my fishing boat, and with all the gear it comes in around 1200lbs, quite a bit less than your 7500lbs, but I was told that as long as the tranny temp gauge is in the green, it is fine to tow in O/D. I am in the Midwest also, and towing it down I-70 in O/D, the truck did great and the tranny temp gauge never moved even on the "hills and bumps".
_____________________________________________
Galaxy Black 2005 Crew Cab SE 4x4 w/ Big Tow
Mods: AEM Brute Force CAI, NCD 2" leveling kit, Nitto Terra Grapplers, '05 "Y" to '07 "H" pipe exhaust swap w/ Magna Flow muffler
HiggySTL is offline   Reply With Quote
Old 03-30-2007, 09:14 AM   #6 (permalink)
TruckinTitan's Avatar
I haven't been towing very long but can you explain to me why I would get more mpg towing in 4th rather than 5th/OD? I would think that if my RPM's are lower I'd be getting better gas mileage...
Please explain...
TruckinTitan is offline   Reply With Quote
Old 03-30-2007, 09:28 AM   #7 (permalink)
Please explain...
Low RPM's don't always mean better mpg. Kinda like lugging a stickshift in fifth instead of going into 4th. One would have to push down the gas pedal more in 5th than in 4th to accompllish the same speed in certain conditions. Since he's loaded heavy and has a larger coefficient of drag w/trailer, he would get better mpg in 4th. That's just my little theory though.
2000 yz426f: stock
Old 03-30-2007, 10:19 AM   #8 (permalink)
Interesting theory... I'm as loaded down... (5,500 lbs boat and trailer) but I think I'll test your theory with my application and see what my results are. Next time I make the trip to the lake house I'll pull in 4th all the way there at70. Then pull in 5th/OD on the way home and see what the difference is.
Thanks for the thoughts
Truckin Titan
http://www.cardomain.com/ride/2438993
06 CC White SE
Mods: 22" Neeper N6's ,Nitto Terra Grappler 325/50/22, CST 4" spindle, Radflo 2.0 , Bilstein Shocks, Fabtech 2" block, Airlift Bags ,4 10" Infiniti Reference Series Subs, Glassed box all under the back seat, Boston Acoustics GT 28 amplifier
(1100 watts at 2 Ohms), Flowmaster Tip, Stillen Big Brake Kit, LED license plate lights, 2 degree timing advance. (Thanks Uprev guys!)
Old 03-30-2007, 10:40 AM   #9 (permalink)
Clint's Avatar
I disagree as was posted elsewhere in this forum. When towing a load the gears mesh deeper than in normal driving and those parts of the gears need to be tempered for that reason. If you skip this procedure you're taking a risk. Why would Nissan know this or bother to include it in the manual. It's to keep up happy and out of the shop. We don't want a failure and they don't want to pay to repair something they could prevent.
Clint
You have two choices in life:
Old 03-30-2007, 12:31 PM   #10 (permalink)
Cool. I haven't been able to test my theory cause I either tow 1,500lbs or 8,000lbs or more. I don't want to tow in O/D with 8,000lbs.
2000 yz426f: stock
Old 03-30-2007, 02:33 PM   #11 (permalink)
Learjet's Avatar
Tow that trailer in 4th !!!! You are not doing your mpg, transmission and engine any favors by bogging it down with that weight and drag. Also, up a long grade use 3rd to stop it from shifting back and forth between 3rd and 4th.
I use cruise control very carefully when not in traffic. Also, I recommend no more than 65 mph.
FYI: I have towed my Travel Trailer over 7000 miles with the Titan, Enjoy!
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 03-30-2007, 02:50 PM   #12 (permalink)
Learjet's Avatar
remember... boats and Travel trailers tow differently due to the higher frontal area with a Travel trailer and the extra power needed to overcome this drag and pull it down the road. My Travel trailer may as well be drag chute. LOL
Born 5/06
Old 03-30-2007, 03:16 PM   #13 (permalink)
RobKar's Avatar
Keep that tyranny in 4th with that weight and save your tyranny from "hunting" ... I have an 8,000lb TT and would never consider towing in OD.
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 03-31-2007, 12:46 AM   #14 (permalink)
For you theory buffs...
Towed 5800 GVWR trailer/car combo with bed fully loaded (refrigerator, camping gear, etc., etc.) from San Diego to Kansas. Up hills and down. Left it in O/D for all but the steepest hills, down shifted for control on those. Got GREAT mileage with Tow Mode on. Worse when I forgot to turn it on. Best mileage was across Arizona and New Mexico, 17.5 MPG. Drier air may have helped. I drive the 04 Titan 4x2 LE Quad Cab with Big Tow package and all the other bells and whistles from the factory (except 4x4, NAV, and DVD). It was the most comfortable long distance ride I have ever experienced.
jcrassoc is offline   Reply With Quote
Old 03-31-2007, 02:10 PM   #15 (permalink)
Learjet's Avatar
Just following the manufactures instructions!
Born 5/06
hawaii cruise 808_TITAN Off-Topic Discussion 1 07-24-2005 04:18 AM
?Cruise Control While Towing jeffs8269 Titan Towing & Hauling 13 03-12-2005 11:06 PM
Shakedown cruise! Tom-ADC Titan General Discussion 9 10-08-2004 11:30 AM
Cruise control Henny Titan Problems & Dealer Service 6 07-26-2004 03:00 PM
