Old 05-13-2007, 09:59 AM   #16 (permalink)
Nissanloyalist's Avatar
Re: New 5er set up
Originally Posted by Reaper
I just purchased a 25ft 5er 7,400# with 1,300# pin with Pull-Rite 12K super-glide. I did not put in airbags and it is maxed but not to bad. My problem I have is if the road is the least bit bumpy I get this push/pull oscillation that is really annoying ? Do you think this is due to overloading the springs because I do not have airbags ? You can pull a 90 degree turn ? best I can get is about 60 degree. What is distance from the front of your trailer to king-pin ?
The oscillation or "chucking" is common w/ 5ers. Airbags will help a little but look into the 5th airborn king pins. The almost eliminate this. I cannot do 90 deg, I am about were you are. I have not mmeasured that because there were no problems reported for the Titan on pullrites site or my dealer who have done a couple Titan pullrite hitches now. Also I really like my sway bars. This truck is near rock solid now w/ the fifth wheel. OZnly thing I have found w/ hooking up is make sure you get the king pin and hitch as level to eachother as possible. With the front end of the truck bieng lower this hitch can hang up and won't let go of the trailer or lock until they are pretty even. My buddy has the 16k slider and his is the same way on his dodge.
04 CC SE Smoke 4x4 DVD OR BT. AEM Brute Force CAI, Magnaflow Muffler, Fitch Fuel Catalyst, Firestone Airbags, Mag-Hytech Diff cover, Stillen front & rear sway bar. Scangauge II. Superchips Cortex Programmer. Stainless rocker panels. Pull-Rite 12k and Prodigy controller for the 2007 Cougar 278RKS. Amsoil throughout!
Nissanloyalist is offline   Reply With Quote
Old 05-13-2007, 10:28 AM   #17 (permalink)
Re: New 5er set up
Thx !!! Do you have any chucking problem ? Have you had any issues backing into sites with only 60 degree turn angle ?
Reaper is offline   Reply With Quote
Old 05-13-2007, 12:45 PM   #18 (permalink)
Re: New 5er set up
I do a little but it is at lower speeds. The only problem I have is trying to back it like a TT. Thats a no no. With how much sharper it turns even with less turning I have found longer approaches and less steering manuvers works well for me even in tight spaces. It is much different than a TT but I love it. What brand and model did you get.
Old 05-13-2007, 03:48 PM   #19 (permalink)
Re: New 5er set up
Triple E 254SSXL, they are made 60 miles from were I live and the quality is top notch ! They are a little heavier because of that.
Old 05-14-2007, 11:14 AM   #20 (permalink)
Re: New 5er set up
Firestone ride-rites. They are set at about 45 lbs. in the pic. I really like them they do a great job.
Any issue on the install with all the brakets for the super-glide hitch on the frame ?
Old 05-14-2007, 01:34 PM   #21 (permalink)
Learjet's Avatar
Re: New 5er set up
Did you look to see if you are riding on the axle bumpers, or how close they are to the frame?
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 05-14-2007, 03:18 PM   #22 (permalink)
Re: New 5er set up
Still some room to move but it is sagging to much.
Old 05-16-2007, 05:53 PM   #23 (permalink)
Re: New 5er set up
The only hicup is I need to modify my mounts for the airbags a bit. They had to remove some of the brackets on the airbags for the hitch. Other than that no issues at all.
Old 05-18-2007, 04:29 PM   #24 (permalink)
Re: New 5er set up
Any chance you could take a picture of what they did or explain in more detail ? Thx !
Old 05-18-2007, 04:44 PM   #25 (permalink)
Re: New 5er set up
I have the valley rails and Reese 15k hitch for my 30.5 Jayco. Dry wt is 7350 with king pin at 1700. Firestone ride rite air bags work great. Pulls very easy with big tow and 4th grear. Get 10.2 MPG pulling mostly through the mountains. Titan does grrreat.
goldwing is offline   Reply With Quote
Old 05-18-2007, 07:38 PM   #26 (permalink)
wiskers's Avatar
Send a message via Yahoo to wiskers
Re: New 5er set up
I didn't know it was possible to fit a 5th on a CC cuz the bed is too short plus the hitch should sit just in front of the rear axle. So that's not much space.
-2005 Nissan Titan LE CC 4x2 Smoke with Navigation, DVD Package, Big Tow, RF System, Captain Chairs, Leather Seats, Sunroof, and more.......
MODS: 2.5" Cornfed mini lift, 6000k HID kits for low & fogs, Volant LED tail lights, all factory bulbs have been replaced w/ LED's, chrome tailgate trim, chrome window seal trim, chrome door moldings, 20% tint, *******'s smoked 3rd LED brake light, Bently style mesh grille, LUND stainless steel bug shield.
FUTURE MODS: APSIS wood dash kit, A.R.E. LSII tonneau cover, and headrest screens
-1999 Dodge Neon (Trailer Queen Show Car)
wiskers is offline   Reply With Quote
Old 05-18-2007, 10:56 PM   #27 (permalink)
sprintn's Avatar
Re: New 5er set up
SWEEEEEEEET! I've looked at the pull-rite and it pretty much told me that I had no option of a 5er that I would consider....... You have proven that it Can Be Done! I understand the turn radius, as C-pillars and rear windows can get crushed. I have looked at 5ers based on their "hook" point. looking for those with the "hook" fartherest foreward.
Last week comming home from TN, I saw a KC with a 5er, and was regreting my upgrade to the CC. NO LONGER. What an inspiration............
TY!!
SUPER POST!!!!!!!!!
POST l/w/h of your Cougar please! As well as the "HOOK" point. How far forewad of the trailer is it?
David
Just upgraded to ' 08 CC LONG BED PRO 4X / OR/ BT/ Utilitrack MAJESTIC BLUE! Previous was '06 CC SE 4X4 /POP/ RF/ OR . Mixed feeling on the cost of the upgrade, But I LOVE it as much as the '05 King Cab and the '06 Crew Cab!!! The only thing I hate is scrubbing the right rear tire on curbs due to the extra length!
[color="Teal"]
Tekonsha Prodigy Brake Controler
In chanel front vent visors.
OEM '06 CC NERF BARS
NISSAN/ TITAN FAMILY:
Significant Other '06 ALTIMA 2.5 S/ Special Edition Pkg
Older brother '06 CC LE Majestic blue 2X4 LOADED no BT
Younger brother '05 CC SE Charcoal 4X4/ POP/ BT
sprintn is offline   Reply With Quote
Old 05-19-2007, 09:22 AM   #28 (permalink)
Re: New 5er set up
Works fine just can not turn 90 DEG when backing up.
Old 05-19-2007, 10:19 AM   #29 (permalink)
Re: New 5er set up
TY!!
SUPER POST!!!!!!!!!
David
Length is 28'8" width is 8' and is 11'8" high. dry weight is 7000# and dry pin weight is 1140# dry w/ 300# hitch weight (pull-rite hitch). Also as you can see in the pics ther is enough room in front of the hitch for some items such as wood BBQ etc. The "hook" point you are refering to is the point or measurement from the pin to the front of the trailer. Mine is about 8" from the center of the pin to the point on the trailer that will hit the cab. Yes you cannot go 90 deg, but I am able to get into just as tight of spot or tighter than a TT w/ this set up. Also this is part of Cougars 1/2 ton series. These are designed to be towed by trucks such as ours. Here is the wbsite. http://keystone-cougar.com/ I hope this helps.
Cougar Model 278RKS Specifications
Weight 7000
Carrying Capacity 2940
Hitch 1140
Length 28' 8
Width 8'
Height 11' 8
Fresh Water 45 gal.
Waste Water 38 gal.
Gray Water 76 gal.
LPG 60
Tire Size 225/75D15D
Rim Size 15 x 6
Old 05-19-2007, 01:38 PM   #30 (permalink)
Re: New 5er set up
Pic one is the frame bracket that is right under the bed. Pic 2 is the airbag under the hitch bracket and as you can see the "ears" that hug the frame are now unable to sit up there right so I am having those "ears" removed and the top of the airbag bracket welde to the bottom of the hitch bracket. There are four brackets to hitch that hold four posts inside the bed that can be totally removed. You have four approx 1 inch diam holes in the bed and they do not interfere with the utility track at all. So when you take the hitch out there are only 4 small holes in the bed. Pic three is just the other side (passanger side) airbag. All bracketry is under the bed and out of sight. The RV dealership said that short of the airbag dilema the install was flawless and very easy. Took them about 3 1/2 hrs to install. I hope this helps.
new-5er-set-up-5er-pics-014.jpg  new-5er-set-up-5er-pics-015.jpg  new-5er-set-up-5er-pics-016.jpg
