Dumb question but here goes. Uhaul can install a class III hitch for about 160 dollars without relays etc. Are Uhaul hitches safer than factory ones? I am going to be towing a jayco jayfeather sport that weighs under 4000lbs. Is a class iii safe? Thanks
For right now forget the class, what is the hitch rated at?
The factory Nissan hitch is a ClassIV rated at 500/5000 without a wd, and 1000/10000 w/ a wd hitch.
You still need a couple of relays, why not get the factory hitch kit, it comes with hitch, bolts, relays and can be bought for not too much more then the U-Haul...
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
There really is nothing wrong with the u-hual hitch, but by the time you buy the relays needed and the adapter bracket for the 7 pin, you do not save any money. You can buy a hitch kit from the dealer, I think I paid $220 and it came with everything needed.
$220, not bad! I called my dealer and they're quoting me at almost $400!!!!!
Thanks guys for the info. I think I am going to go with nissan.
TITANSTEELER just found this Nissan Hitch from www.yournissanparts.com. It comes with everything but the hitch ball and ball mount. It's priced just under $220 not including shipping and handling. Here is the description:
Description:
Nissan Titan Receiver Hitch
Didn't buy the BIG TOW Package with your Titan? Never Fear, we have the kit right here! You get the receiver hitch,relays,wiring, instructions!! Everything but the hitch ball, and hitch ball mount. Factory Hitch Receiver.
Rated up to 7,500 lbs.
Custom Nissan frame-mounted design for secure towing strength.
7-pin connector mounted to the outside of receiver hitch for easy
connection to trailer wiring (All Titans are pre-wired for Hitch)
Accepts either Class III or Class IV hitch ball mounts (sold separately)
Thanks Big Al. I also came across that deal, but I am worried about the install. I'm sure i could install it but will I tighten the bolts enough?
I called Uhaul and they would not do the install unless its one of their products. They priced their hitch with the wiring, no relays, installed for 250$
Get a torque wrench, TITANSTEELER. You'll need it for future projects anyways.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Great advice for anybody who owns a tool box.
O6 4X2 Granite SE CC, Big Tow & SE Popular Pkg, Nissan bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension
