Old 06-07-2007, 10:15 PM   #1 (permalink)
Towing with 24s?
Right now I have my truck lowered in the rear with the PRG rear lowering kit, which still allows full load and tow capacity, with some 22s, but right now the 22s just feel too small for the truck and I really want to do a 24, but am nervous because I am going to be towing a 3,600lbs boat up to my cabin and back a few times this summer. Can I do a 24 and still tow the boat without bending rims or something of that sort? Thanks in advance.
YZmoto125 is offline   Reply With Quote
Old 06-07-2007, 10:20 PM   #2 (permalink)
titan814's Avatar
Re: Towing with 24s?
just dont run a super low profile tire and your straight. my mom drives a navigator on 24's and they tow our 5000lb boat with no worries..
400hp LS6 CTS-V (the caddy that zigs)
titan814 is offline   Reply With Quote
Old 06-07-2007, 10:37 PM   #3 (permalink)
The tire I would run is problably the nitto 420s 315/35/24, which is pretty low pro I would think? and im very jealous, I wish my mom drove a navigator on 24s and pulled a boat around!
Old 06-08-2007, 07:57 AM   #4 (permalink)
loufish's Avatar
you're right, pull off those "wagon wheels" and get some real truck tires!
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-08-2007, 08:19 AM   #5 (permalink)
Armada's Avatar
Yep, 24's are for show, 17's for tow and for go.
Just one opinion.
Armada
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
Old 06-09-2007, 08:35 AM   #6 (permalink)
Im not looking for opinions of what I should do with my truck. I personally like the look of 24s on a truck, others dont, its my truck.
However what I am asking is if I am going to run into problems towing a 3,600lbs boat with 24s? Thanks.
Old 06-09-2007, 09:55 AM   #7 (permalink)
JnasTy0085's Avatar
Send a message via AIM to JnasTy0085
i tow about 2800 on my 24's... no worry what so ever. You will be fine but i would tell you to consider a larger side wall. also when i bought my wheels and tires i told them that i tow 5000lbs 3 times a week so instead of the nitto's i went with cooper... they have the over-load tire for towing. maybe this will help you? look at some 295-40's the load rating is by far better than stock tires... but the tire isnt going to be the biggest problem... explore and research on what wheel your going to be purchasing.... for different wheels have defferent load ratings... hopefully this helped
2004 KC SE
BIG-TOW
DUAL IN/OUT MAGNAFLOW BUILT IN X-PIPE
AIR BOX MOD
24 INCH RADD RD14'S
305-35-24 COOPER XST OVERLOAD TIRES
CUSTOM BOX 2 10' ALPINE TYPE-R
CHROME PILLARS, TAILGATE TRIM AND HANDLE, GAS GATE COVER, TAIL-LIGHT TRIM.
JnasTy0085 is offline   Reply With Quote
Old 06-09-2007, 10:09 AM   #8 (permalink)
Send a message via MSN to Toomnymods Send a message via Yahoo to Toomnymods
problem imo isnt going to be the tires it will be the stopping power.. better upgrade to a bigbrake kit from stillen..
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Dynotech Dyno SAE #'s
N/A Map 330.12 RWHP / 367.59TQ in 96F heat
N20 Map = 430 RWHP / 515TQ
UpRev ECU Tuning!!
Toomnymods is offline   Reply With Quote
Old 06-10-2007, 11:56 AM   #9 (permalink)
SoBeGraphics's Avatar
you will be fine towing. i tow a 23 foot open fisherman, gear, and four people without any problems. do it you wont regret it.
2005 Titan LE Crew - Galaxy - BT - BANKS - AEM - BLACK BOX TUNER - Dyno @ 298 rwhp / 359 rwtq
Weeeheeheeheehee. Click Here
SoBeGraphics is offline   Reply With Quote
Old 06-10-2007, 07:11 PM   #10 (permalink)
I dont think there i a stright foward answer to that
It s gonna depend on the wheels and tires your putting on your truck
I have american racing 22" wheels and falcon tires and the load ratings are equal and better
Just check the wheel and tire ratings
A different problem might be overall diameter of the wheel and tire combination and by going larger diameter you decrease your final drive ratio and that will lessen what you can pull to a small degree
hope this helps
Bill
alum1000 is offline   Reply With Quote
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 06:48 AM
Towing 4th or 5th. JKB Titan Towing & Hauling 8 07-21-2006 06:01 AM
9600 lbs towing! try 17000 lbs towing standingtall Titan Towing & Hauling 1 12-08-2005 04:48 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 01:03 PM
Towing UTAHTITAN Titan Towing & Hauling 1 03-23-2005 10:31 AM
