Old 06-21-2007, 07:52 AM   #1 (permalink)
Air Bags vs. Weight Dist. Hitch!
I will be towing around 6,000 lbs. with a 750lb. ATV in the back of the truck. Which would be a better investment. The Air bags or weight dist. hitch?
XRING600 is offline   Reply With Quote
Old 06-21-2007, 08:23 AM   #2 (permalink)
thclimer's Avatar
Re: Air Bags vs. Weight Dist. Hitch!
My recommendation is you need both. Nissan recommends a WD hitch when towing anything above 5,000 pounds and with the additional 750 pound ATV, you are looking at a load of 600+750=1,350 pounds in/on the rear end. My next concern would be your tires, are they rated for the load? I personally could not justify my safety and the value of my personal property without using both the WD and air bags, let alone if you are in a accident and others are involved your liability.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
thclimer is offline   Reply With Quote
Old 06-21-2007, 09:07 AM   #3 (permalink)
The weight distibution hitch transfers weight to the front of the truck balancing out the load on the suspension. When Equalizer first came out they had a Tornado pulling a trailer with the cars rear wheels removed to demonstrate the weight transfer. The airbags will raise your bed but all the weight will be on the rear axle. If you can't put the ATV in the trailer then I'd say you need both but will still be over max payload.
04 LE KC OR BT
Firestone ride rite airbags
Equalizer hitch
26' Sportsman Sportster Toy Hauler thats HEAVY
AMCS is offline   Reply With Quote
Old 06-21-2007, 09:36 AM   #4 (permalink)
Carbeaux's Avatar
IMHO, the W/D hitch isn't an option for you. It's necessary. The bags might be optional, depending on the sag you get, and it will be significant with what you're planning. So I'm going to say that's a very high probability for both of these being needed as well.
Hook 'Em Horns!
- Frank Zappa
Carbeaux is online now   Reply With Quote
Old 06-21-2007, 10:16 AM   #5 (permalink)
Derwud's Avatar
Get them both.. I had just the Equal-I-Zer for a while and it was great, but I have both now and it is even better. I get so little sway it's amazing..
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 06-21-2007, 12:01 PM   #6 (permalink)
Justintoxicated's Avatar
DEFINATELY both.
Old 06-21-2007, 12:11 PM   #7 (permalink)
Am I the only one that only ran with air bags?? I had no probs with only air bags on a 7000 lb trailer. No sway issues. No sagging. I had a friction sway bar, but thats it. I wouldnt tow without a sway bar. The nice thing about air bags is you can change trailers and still pull with no sagging.
Old 06-21-2007, 12:24 PM   #8 (permalink)
It can be done but is much safer with the hitch, especialy if your not pulling on level ground.
Old 06-21-2007, 02:57 PM   #9 (permalink)
How do you attach the sway bar to your hitch?
Old 06-21-2007, 03:15 PM   #10 (permalink)
I dont have any pics on this comp. I will put some pics up when I get home tonight.
Old 06-21-2007, 05:31 PM   #11 (permalink)
deebie47's Avatar
Exactly how would a person go about leveling the trailer then? Level with the air bags or the hitch?
'05 Deep Water Blue LE KC, Big Toe, 4x4,
Nissan Tonneau, Bug Deflector, Rear Underseat Storage, Keyless Entry Keypad,
Weather Tech Floor Liners,
Escort 8500 Radar Detector,
Single Line Firestone Air Bags,
Active Tuning Ground,
AEM CAI,
Magnaflow Cat-Back,
Motorvator TBS
'05 Pilgrim Travel Trailer ( 26', 8400 # Loaded)
Prodigy
Equal-I-Zer Hitch
deebie47 is offline   Reply With Quote
Old 06-21-2007, 06:00 PM   #12 (permalink)
Derwud's Avatar
I level with the hitch as best I can and use the air-bags to help rear sag, bounce and sway.
Old 06-22-2007, 12:52 PM   #13 (permalink)
Steamguy's Avatar
^^^^^^ This isn't a good idea, and the reason that Nissan recommends using a W/D hitch is to get the load on the WHOLE truck chassis, so that the front helps carry the load and not just have it all on the rear axle. You're looking to cause a rear axle failure due to the high loading. I bet if you weighed it, you'd be close to or over your rating for the axle. Think about it for a second: 7000# trailer, properly loaded, means at least 700# on that rear axle alone. And behind it, at that, since it's in a receiver.
Also consider that by having more of the weight on the front, you're helping with control issues. If the weight is mostly in the rear, then the whole truck chassis isn't available to compensate for any transient loading.
Old 06-22-2007, 01:24 PM   #14 (permalink)
Derwud's Avatar
See earlier post, I have an Equal-I-Zer hitch (Sway and W/D) and added the air bags for and added bit of security.
Old 06-22-2007, 05:04 PM   #15 (permalink)
Steamguy's Avatar
Sorry, Derwud. The incredulousness was at Helinut's post...
weight rating of oem hitch dank78 Titan Towing & Hauling 8 11-26-2006 11:32 AM
Hitch weight edanger23 Titan Towing & Hauling 1 09-13-2006 05:17 PM
Anyone use Nissan's weight dist. hitch? jrfarrar Titan Towing & Hauling 12 02-07-2006 03:12 PM
weight distribution hitch or not? GO_VOLS! Titan Towing & Hauling 18 01-25-2006 08:34 AM
Help Selecting Weight Distribution Hitch Justintoxicated Titan Towing & Hauling 20 05-13-2005 04:48 PM
