Old 06-21-2007, 04:03 PM   #1 (permalink)
Cool towing mod help.
I have a 05 crew cab that is stock. i pull a 31 foot tt. I have the prodigy brake controller and equilizer hitch.
I would like to know thw best after market mods i can do to improve my towing . I am getting the ride rite to help with me sag problem. thinking if getting the timing advance. I saw a air intake system on ebay called r one i might get that . Can anyone help with what the best mods may be for me.. thanks..
buckeyewhis is offline   Reply With Quote
Old 06-21-2007, 06:04 PM   #2 (permalink)
Derwud's Avatar
Re: towing mod help.
Careful with Air Intakes, if you climb a lot of hills it will be noisey, the Box style like Volants seem worse (had one on my '04, wow it was loud while towing up a hill). The timing advance is good for towing along with exhaust.
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 06-21-2007, 08:15 PM   #3 (permalink)
loufish's Avatar
A set of DR shocks in the rear should tame the rear end...The more spring you put on, the more you need better shocks.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-21-2007, 09:15 PM   #4 (permalink)
AF-Medic's Avatar
The best mod for towing would be getting a diesel. Watch out with changing the exhaust, you could loose torque without back pressure. Good luck
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's Shift Pass You
AF-Medic is offline   Reply With Quote
Old 06-22-2007, 05:11 PM   #5 (permalink)
yep
Adding an intake and exhaust really won't make a difference. The best thing that you can do is make sure that your hitch is properly adjusted and pack light.
rtapia is offline   Reply With Quote
Old 06-23-2007, 12:48 PM   #6 (permalink)
Shift manually. Leave the kids. Intake and exhaust.
Titanminator is offline   Reply With Quote
Disappointing Hemi towing experience (from towing forum) karlconnell Titan Towing & Hauling 11 12-19-2007 06:48 AM
9600 lbs towing! try 17000 lbs towing standingtall Titan Towing & Hauling 1 12-08-2005 04:48 AM
Towing experts: Question about towing long trailer ptgarcia Titan Towing & Hauling 15 04-18-2005 01:03 PM
Towing UTAHTITAN Titan Towing & Hauling 1 03-23-2005 10:31 AM
Towing NOVICETOWER Titan Towing & Hauling 57 02-22-2005 04:46 PM
