I had the dealer tighten it all the way down when it was in for the rear end failure and it did raise the rear about an inch. It improved the cornering even more but I didn't get much a chance to test that as it was pouring that day and I have been in mexico since. I will be home sunday and plan on taking her for a run on monday. If you only have it at a dime for the spring I would say you have it under tightened, I have mine all the way maxed out now and ride quality is still great.
Ok another update, Took out the Toy Hauler this weekend which should be about 8000-8500 lbs and it handled like a dream. When connected to the trailer the rear did dip some but even with the lowering kit on it wasn't that low and worked great. Sway was evident as it was storming, or I should say it was trying to sway but the RAS seemed to instantly negate it. You would feel the rear end start to sway and then just stop. I am absolutely impressed with this system and recommend it to anyone!
I was looking into getting either sway bars or the RAS. Does anyone know if these can be used together or if it must be one or the other? Also does anyone know if installing this myself will affect the warranty?
The RAS acts as a rear sway bar so that makes a rear sway kind of redundant and it does a good job as a rear sway bar. I am still going to pick up a better front sway bar as well.
Shouldn't be any problem with that, it is pretty easy, just read through it a couple times and make sure you understand it so you don't waste time doing things redundantly. I would say it really takes about an hour to hour and a half doing it yourself with a lift or good set of jack stands and jacks.
I know this thread is stale but there are several on Ebay right now for $69.95 or so. I have a bid on one right now.
2008 4X4 Se CC LWB "Timberline", Popular Package w/Heated Captain Chairs, Big Tow, 1Start remote starter, BullyDog Premium Tune, WOT, 2* Timing Advance, Westin Sure-Grip Side Steps, Injen CAI, Active Tuning Kit, Armada Aero Spoiler, Oem Hood Protector, OEM Bed Extender, Vent Visors, HotShot Wiper Fluid Heater, HID 6K Low/Fog, Line of Fire LED bar, OEM Nav Bezel, Garmin Street Pilot 7500, and Boyo VTL350 Backup Camera, Myron and Davis DVD, Overhead Monitor & Head Rest Monitors, Leer 100R Truck Cap, RoadMaster Active Suspension, N2 filled tires, and 2 Nissan Titan Hats
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
are those the right ones for the titan???...anyone know for sure??....i checked the ref. guide and there is an item # /ref. # ....just making sure these will work...it's a too good to be true deal
thanks
tone
