Old 03-21-2008, 11:31 AM   #31 (permalink)
cneary812's Avatar
Re: Roadmaster Active Suspension = AWESOME!
Originally Posted by deftone
are those the right ones for the titan???...anyone know for sure??....i checked the ref. guide and there is an item # /ref. # ....just making sure these will work...it's a too good to be true deal
thanks
tone
I double checked them before ordering them myself from the place where I was going to buy them from and the number was the same so I ordered them ---wow what a runon sentence---
the MKII-XXF is the model for our truck
NISSAN
YEAR MODEL 2X4 PART #
1986 - 04 PICKUP - 4 Cylinder MK I (XTF)
1998 - 04 PICKUP - 6 Cylinder MK I (XTF)
1999 - 06 XTERRA XE SUV MK I (XTF)
2004 - 06
TITAN PICKUP MK II (XF) / (XXF)
YEAR MODEL 4X4 PART #
1986 - 04 PICKUP - 4 Cylinder MK II (XTF)
1998 - 04 PICKUP - 6 Cylinder MK II (XTF)
2004 - 06
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
NCD leveling kit installed 3/10/09 Thanks Adam!!
MVP Titan sticker on 3rd brake light.
2º Timing advance, Thanks John! 11/14/09
future mods - JBA Evol , Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 03-26-2008, 01:48 PM   #32 (permalink)
Anybody using just the XF kit, or is the XXF the one to go for? I tow a travel trailer and all the camping stuff that goes with it, and need the kit that'll do the job. The truck's rake, unloaded, is another concern of mine. From what I've read, it sounds like the XXF kit is prone to raise the rear end more than the XF when there's no load on the truck. I'd like to keep the unloaded truck's rake as close to stock as I can, or could maybe install PRG levelers on the front end to compensate for the XXF kit, if necessary. Any thoughts?
"I am not young enough to know everything."
2005 Titan SE, 4X4, CC, Big Tow pkg., 2* Timing advance, Airbox mod, K&N drop-in air filter, 2.5" PRG front leveling kit, PRG adjustable rear shackles, PML Diff. Cover, Roadmaster HD Active Suspension System
Graybeard is offline   Reply With Quote
Old 03-30-2008, 06:57 PM   #33 (permalink)
I just got one off of ebay and got the xxf. I figure the heavier should be better for me, my trailer is not real lite.
Terry
Mrhavasu is offline   Reply With Quote
Old 03-31-2008, 06:59 AM   #34 (permalink)
cneary812's Avatar
my xxf kit is sitting in my living room and it is perfect. I will be installing it hopefully tomorrow night.
airbox mod with K&N
Old 03-31-2008, 11:14 AM   #35 (permalink)
Ditto - except it's not in cneary812's living room but in my garage.
2008 4X4 Se CC LWB "Timberline", Popular Package w/Heated Captain Chairs, Big Tow, 1Start remote starter, BullyDog Premium Tune, WOT, 2* Timing Advance, Westin Sure-Grip Side Steps, Injen CAI, Active Tuning Kit, Armada Aero Spoiler, Oem Hood Protector, OEM Bed Extender, Vent Visors, HotShot Wiper Fluid Heater, HID 6K Low/Fog, Line of Fire LED bar, OEM Nav Bezel, Garmin Street Pilot 7500, and Boyo VTL350 Backup Camera, Myron and Davis DVD, Overhead Monitor & Head Rest Monitors, Leer 100R Truck Cap, RoadMaster Active Suspension, N2 filled tires, and 2 Nissan Titan Hats
To be Installed: *Nothing*
gksmith is offline   Reply With Quote
Old 03-31-2008, 11:28 AM   #36 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
i have an 8 inch suspension lift and 3 inch body lift. does anyone know if this will system will work? is it like an air bag system or what?
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 04-01-2008, 06:42 PM   #37 (permalink)
Just got my installed today, the ride is awesome. I am having a little bit of height difference, left side is higher than the right side. How do I adjusted them?
2008 titan XE, black on black, 4x4, CC, tow package with big tow mirrors, preferred package, spray on bedliner (SOLD).
2008 Titan Pro-4x, silver with two tone interior, NO Fear Package, 2 degree timing advance.
9sec95autoTT is offline   Reply With Quote
Old 04-01-2008, 08:32 PM   #38 (permalink)
Finally got the height adjusted. Is it okay if two side spring tension is different? One side spring tension is about 1mm(dime size) and the other side spring tension is 2.5mm. I don't know if this is okay? Are the the spring tension suppose to be the same on both side?
Old 04-03-2008, 11:46 AM   #39 (permalink)
Did you do your own install? I can't believe I can't find anyone with a jack that will lift the entire rear at the same time so I can use the jack stands.
I don't want to use my bottle jack but will if I have too.
Old 04-03-2008, 06:18 PM   #40 (permalink)
there is no real way to get the exact same tension. On older trucks, the torsions used to vary from left to right all the time.
2007 Nissan Titan SE - Blizzard
Stillen Rear Springs, Nissan Motorsports Front Bilstein Coilovers, Relocated Rear Bumpstops, Tech12Volt sub box, KPTechnologies Modules, Alpine amps.
Future Mods....... 10.4" touchscreen Carputer - 85% complete.
shdw03 is offline   Reply With Quote
Old 04-05-2008, 06:20 PM   #41 (permalink)
rtc1184's Avatar
so i am guessing no one knows if this system will work on a truck with a 8" suspension lift?
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
Old 04-21-2008, 06:24 AM   #42 (permalink)
cneary812's Avatar
I finally got a chance to do my install Saturday Night. It seemed to raise the back an inch or so but the ride is great.
After doing the install I can say that yes your 8" lift should still work with this kit. There is no reason that is shouldn't work. It bolts under the U bolts and over the leaf so height should be no factor.
airbox mod with K&N
Old 05-06-2008, 09:01 PM   #43 (permalink)
titanpat57's Avatar
Got mine off Ebay the other night..should be here next week!! Any tips or tricks would be helpful. Every man's dream...Bilstein shocks coming..RAS on its way too... and a week of vacation. Ohh..did I mention the Mrs. is heading to Phoenix on business the next whole week too?...lol. Just me and baby out the driveway doin' the nasty!
2006 4x4 CC Radiant Silver LE - Lazer Lite Cover - Volant CAI and Tails - Keyless Entry (thx BBF) - Big Tow LED Turnsignal Mod - Handmade LED Backup Lights - Remote Start - Front AirDam - Front Tint - Ventshades - SS Sills - SS Tailgate Cover - SS 3rd Brake Cover - Bilstein Struts - As many friggin' LED'S I can get my hands on!
titanpat57 is offline   Reply With Quote
Old 05-07-2008, 07:07 AM   #44 (permalink)
cneary812's Avatar
it is an easy job. Make sure you have a good floor jack. level surface and a good set of jack stands. You will need to jack up the center pumpkin and put the jack stands under the axle first to get everything on, then drop the axle and have the stands under the frame to adjust the spring tension. Also in the directions it says to put the threaded rod in about an inch into the spring... I did that on the one side and realized that the thread has to go almost all the way through the spring so on the other side I ran the spring almost all the way in just enough for me to still get the hook over the leaf. It will make your life a little easier. You will have to take off the plastic wheel well covers to get to the leafs. Also if you have utilitrack you will have trouble getting to the drivers side nuts due to the lock box. I ended up using a open end ratchet to hold the top of the nut. Also you need to take off the rubber bump stop that is on top of the leaf. It is a small allen (don't remember the size off hand). use lots of wd40 on those parts the day before you do this job.
thats about it...
good luck
airbox mod with K&N
Old 05-07-2008, 08:34 AM   #45 (permalink)
Quartz's Avatar
So let me see if I get this right. If I install this it will help with axle wrap. It will raise the back end of my truck about and inch but it will help keep it from squatting when I put a load in the back. It makes the truck ride better. I can adjust the ride stiffness. Is this all true?
What is the downside? It is difficult to adjust the ride stiffness? Is it something that you can easily adjust when you fill the truck with a load of stuff on the weekend and back to normal when the weekend is over?
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Roadmaster Active Suspension Sea Monkey Titan Suspension 0 06-22-2007 08:32 PM
awesome forum & awesome truck!!!! vulcanrob Titan General Discussion 14 05-08-2007 08:46 PM
Roadmaster Active Suspension casique Titan General Discussion 1 07-04-2006 12:26 PM
roadmaster active suspension ensclark Titan Suspension 0 01-29-2005 12:05 PM
active headrest gtbigup01 Titan General Discussion 11 10-27-2004 06:12 AM
