Old 11-07-2009, 06:55 AM   #76 (permalink)
cneary812's Avatar
Re: Roadmaster Active Suspension = AWESOME!
Originally Posted by Yahooligan View Post
Sorry for bringing up a thread from the dead, but this thread seemed to have the most/best info in it and though it would be good to add to it.
So, I'm currently trying to install the RAS and my first issue has to do with u-bolt length. With the RAS bracket AND bump stop centering plate in place I don't have enough length on the u-bolts. There are still a few threads in the nut that aren't used, so what did you folks do to resolve this? Or do I have odd u-bolts? Hellllllp!
so your U-bolts are/were too short? That is strange, mine fit ok, yeah they did shorten up a bit but they were fine.. Make sure that you have the bracket straight or the bolts won't line up right. I have had mine on with ablolutely no problems now and love it. Hope this helps or if not hope you were able to at least get longer ubolts and get it up and running.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
NCD leveling kit installed 3/10/09 Thanks Adam!!
MVP Titan sticker on 3rd brake light.
2º Timing advance, Thanks John! 11/14/09
future mods - JBA Evol , Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 11-07-2009, 10:37 AM   #77 (permalink)
The u bolts were to short on mine also. I did call roadmaster and they said that on some models you have to buy longer ones. I also took the whole setup back off. The rear sagged to much with my toyhauler hooked up to it. I had to go with air bags. They were the heavier ones and I liked the ride improvement.
08 LE CC 4X4
Mrhavasu is offline   Reply With Quote
Old 11-07-2009, 10:40 AM   #78 (permalink)
cneary812's Avatar
you must have a really heavy tounge load for it to sag alot.
airbox mod with K&N
Old 11-09-2009, 12:20 AM   #79 (permalink)
Smoke05's Avatar
Something isn't right. The plates that mount on the leaf spring pack ate only like 3/8" thick if even that. I mounted mine on after I did a PRG minilift with new U Bolts but I seem to remember there being plenty of thead between the nut and end of the U bolt when I removed them.
Smoke05 is offline   Reply With Quote
Old 11-09-2009, 05:33 AM   #80 (permalink)
Quartz's Avatar
I've got to agree with Smoke. Something ain't right. I had plenty of threads left on my u bolts after I installed my RAS.
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
Old 11-09-2009, 07:44 AM   #81 (permalink)
Yahooligan's Avatar
Well, it's not like leaf springs and mounts are overly complex. Nothing is "wrong" other than there are apparently different u-bolts Nissan uses. Before I started pulling things apart I thought I might run into this as there weren't very many threads sticking out below the nut when I started but I thought I'd give it a shot and see if I got lucky. Nope. Oh well.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
Yahooligan is offline   Reply With Quote
Roadmaster Active Suspension Sea Monkey Titan Suspension 0 06-22-2007 08:32 PM
awesome forum & awesome truck!!!! vulcanrob Titan General Discussion 14 05-08-2007 08:46 PM
Roadmaster Active Suspension casique Titan General Discussion 1 07-04-2006 12:26 PM
roadmaster active suspension ensclark Titan Suspension 0 01-29-2005 12:05 PM
active headrest gtbigup01 Titan General Discussion 11 10-27-2004 06:12 AM
