Old 06-30-2007, 10:29 AM   #1 (permalink)
TAFOYA'STITAN's Avatar
towing questions
i have an 2005 cc 4x4 non big tow the only difference if i put a class iv hitch is the gear ratio correct i had a sliverado with 3.73's and i had the same tow ratings as the one with 4.10's should i be able to tow the same amount with the hitch as one with big tow.
TAFOYA'STITAN is offline   Reply With Quote
Old 06-30-2007, 11:22 AM   #2 (permalink)
loufish's Avatar
Re: towing questions
No, the XE non-tow even with the IV hitch is rated to tow 6500 lbs, the SE & LE are rated 7400 lbs non-tow, and 9500 w/tow...
I'm surprised your Chevy didn't have differnet tow rating for the two different ratios...most trucks do.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-30-2007, 11:35 AM   #3 (permalink)
even the new dont say anything different
http://www.chevrolet.com/byo/selectO...th=2&x=20&y=11
http://www56.forddirect.fordvehicles...sh&statetoken=
Old 06-30-2007, 06:00 PM   #4 (permalink)
loufish's Avatar
FYI------Don't go by the website to determine tow ratings, the Ford has them listed in their Owners manual:
SuperCab 4x2 (132.5” wheelbase)
Engine Rear axle ratio: 3.55 w/17" tires - 7600 lbs
3.73 w/17" tires - 8100 lbs
I'm sure if you check the Chevy's manual you will find the same.
Nissan's website doesn't have their whole list of ratings either.
Born 9/2004
2002 Honda XR650R
Towing Questions turk Titan Towing & Hauling 6 05-22-2007 09:06 PM
questions about airbags for towing? jbone Titan Towing & Hauling 8 02-09-2007 10:50 AM
Rookie Towing Questions avgjoe Titan Towing & Hauling 12 02-17-2006 05:39 PM
More towing questions skycruiser Titan General Discussion 5 07-26-2005 11:06 AM
Towing with the Armada... Questions? BlackSnake2001 Titan General Discussion 0 08-16-2004 02:38 PM
