Re: 07 Titan KC SE with Tow PKG
Congats on your new truck!
You shouldn't need anything except an electric brake controller if you plan on towing a trailer with electric brakes, but if not(most boat trailers use surge brakes, no controller needed)then you are good to go...
If you didn't already know, if the trailer weight starts to get up there in weight tow in 4th gear. This helps keep the torque converter locked up which in turn keeps tranny temps down...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
