Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Tekonsha Prodigy Brake controller question. - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 11-22-2007, 06:53 AM   #16
Derwud
Derwud's Avatar
Re: Tekonsha Prodigy Brake controller question.
Originally Posted by blackberry farm
Found it, Thx! Guess I don't need the Illum. Notice you have bags, does it really help the rear sag when towing? What brand did you get?
Yes the bags help with sag, a lot!!! They also help with sway.. run seperate air lines to each side and it will help with sway.
I got the Air lift set from Greg at PRG..
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 04-05-2008, 09:42 AM   #17
greyfeather
I installed my Prodigy V2.6 controller (finished it last night) in my NewToMe 2007 LE CC.
I read the forum postings in several threads and really wore myself out groping and pulling under the dash. I COULD NOT find the connector that BigTow offers. I found one posting that Made Pictures, and that should have been enough.... but NO. In desparation, I finally found the two screws below the dash that hold the bottom half of the dash panel. Removed. Careful pulling and 'working' the panel edges, and it Finally Popped Free !!
There it is !! No way I would have found it with my Groping Approach. Got the extra cost Tekonsha-Titan cable plugged in, and It Works!!
Replacing the panel was a bit of an exercise in careful placement - there are several spring-loaded prongs that keep the panel from shifting after it is snapped back together, and one of the lower screw locations had to be bent back a bit to prevent cross-threading when I put it all back. Easy, but not quick.
The whole thing took about a half hour. I have the Prodigy mount/bucket on the left side of the steering column, so I had to coil up most of the connect cable. Fits under the dash by friction and cable tension.
I'm a happy camper so far. Now to connect the trailer and verify, verify, verify (who was it that said "Trust, but Verify"??)
greyfeather is offline   Reply With Quote
User Name
Password
FS: Tekonsha Prodigy Brake Controller Vegas04 Buy/Sell 3 07-26-2006 02:04 PM
Prodigy Brake Controller bclmread Titan Parts & Accessories 10 07-10-2006 01:13 PM
Prodigy brake controller question... HudsonValleyTitan Titan General Discussion 4 05-17-2006 02:16 PM
Who has best price on Tekonsha Prodigy Trailer Brake controller? ptgarcia Titan General Discussion 3 04-14-2005 05:18 PM
Prodigy brake controller help. Skipete Titan Towing & Hauling 10 05-03-2004 12:32 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
