Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
First Time Travel Trailer Towing - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-06-2008, 11:47 AM   #16
kennmark
Re: First Time Travel Trailer Towing
so just put it to 4 instead of D when im towing 5k lbs trailer? thats considered turning off OD?
sorry im new to this, hi guys.... good forum here
kennmark is offline   Reply With Quote
Old 03-06-2008, 02:05 PM   #17
loufish
loufish's Avatar
Yup...That's it. There is no "OD" switch, just the shift lever posistion...
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
Old 03-14-2008, 03:50 AM   #18
Masa
Masa's Avatar
Originally Posted by Nissanloyalist
If you have had the synthetic 75w-140 then there should be no worries. If you have the factory dino (assuming you have an 04) then yes change to a good quality synthetic.
Mine is an '06. I went ahead and changed the final gear oil. Despite the low mileage since the last change, the oil had more fine particles of metal and did not look as clear. I guess that is expected due to additional break-in of gears. I think it was a cheap insurance to change it. Used Mobil 1 as I always have.
'06 White 4x2 CC LE w/ Big Tow & Bench Seat
San Antonio, Texas
Masa is offline   Reply With Quote
Old 03-14-2008, 03:56 AM   #19
Masa
Masa's Avatar
loufish,
You are correct. Our trucks don't have an "OD" switch. I mistakenly used that word because conceptually, I think of "D" as "top gear enabled". And top gear (5th) equals "OD" to me. Sorry about the confusion.
Old 03-17-2008, 09:38 PM   #20
240gordy
240gordy's Avatar
Originally Posted by Masa
No major grades and the transmission temp stayed in the middle. Luckily every time I forgot about tow mode & getting gear out of OD, it was only a minute or so wafter e started driving when I rememberd or my wife reminded me about it!
You`re lucky! I pulled a 25 ft. travel trailer through the Rocky Mountains and watched my tranny temp go right to the top.......but as soon as it hits that mark the tranny cooler kicks in and you can watch the gauge go down. It cools it off that fast!
240gordy is offline   Reply With Quote
User Name
Password
Towing Jayco Eagle 314bhds Travel Trailer Safely bmmendez Titan Towing & Hauling 18 06-23-2008 08:33 AM
LT Tire Recommendations for towing Travel Trailer happenin-dad Titan Wheels, Tires & Brakes 10 02-10-2007 07:43 PM
Towing a 7000 lb travel trailer mtofell Titan General Discussion 14 12-07-2006 09:09 AM
Travel Trailer towing + ? Tom-ADC Titan Towing & Hauling 21 08-20-2004 10:02 PM
Towing travel trailer - first time Titan Ken Titan Towing & Hauling 0 06-17-2004 10:03 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
