Re: what does it take?
The hitch:
Real easy, get the factory hitch kit, comes with the correct bolts and relays for the trailer lights
The gears:
You would have to do a front and rear gear swap. Since Nissan won't sell you just the ring & pinion you have to either get a used set of frt & rear gears and have them installed, or replace the entire frt & rear diffs...NOW if your truck has the Off-Road package you're in great shape, because it already has the same gears as the Big Tow...
Tow mirrors:
I think those can be swaped with non-tow mirrors, about $230 each new from dealer...
Trans temp gauge:
Temp sensor has to be installed and new gauge package in dash, BUT I'm not sure how much factory wiring is there to accept the sensor and new faceplate...
Sooo much better to get the tow package from the factory...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
