Re: Hitch bolts
Make sure you put a little anti-sieze on them(the hitch bolts) and torque them to factory spec's...Maybe someone here knows the torque spec's, but you could ask the dealer who sold you the bolts.
Even if you find the correct size bolts(I keep thinking 12mm 1.25 pitch) you need the correct grade. I'm sure it's no lower then a 10.9
The grade will be stamped on the head of the bolt.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
