Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Trying to fig'r if I have big tow package - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-11-2008, 02:23 PM   #16
Howorks
Re: Trying to fig'r if I have big tow package
How do I tell of I have the offroad package? Sorry I've only had the truck 2 days! I want to be able to tow 8,000 lbs.
thx
Originally Posted by TitanTeamRoper
The Tow button is standard on all titans, the only other way your titan would be rated to tow the same as the BigTow package is if you have the offroad package that will also give you the tow gears
Howorks is offline   Reply With Quote
Old 03-11-2008, 03:10 PM   #17
NorCal 4x4
NorCal 4x4's Avatar
The Big Tow package has a transmission temperature gauge too, on an '04.
The Off Road package has the front skid plate, also, if it's a May build or latter, (and a 4x4) it will have the e-lock switch down by the tow switch. But earlier '04s didn't get the locker, and '04 2wd Off Road pkg Titans also didn't get the e-lock. All of the Off Road models came with Rancho shocks front and rear too.
Btw, you can download an owner's manual here:http://www.courtesyparts.com/betasit...rs-manuals.php
Old 03-11-2008, 03:23 PM   #18
Big Don
Big Don's Avatar
Originally Posted by BudsbigT
It's weird. I have a 2008.5 and I don't have the big tow package but I do have the Trans gauge. (2008.5 LE KC) Bud
Me to (2008.5 CC SE)
Me 3 (2008.5 CC SE)
Big Don is offline   Reply With Quote
Old 03-11-2008, 03:34 PM   #19
Howorks
Pretty sure I have the off road package. I have a skid plate but no e-lock switch. Plus there are "off-road"decals on side of the bed. Shocks look like the have red shock boots.
Old 03-11-2008, 03:51 PM   #20
TitanTeamRoper
TitanTeamRoper's Avatar
I would think so too by what NorCal said.
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
TitanTeamRoper is offline   Reply With Quote
Old 03-12-2008, 09:20 AM   #21
bigboytitan
bigboytitan's Avatar
Send a message via Yahoo to bigboytitan
Ok so I also have a 2008.5 CC SE 4X4, I have the trans gauge on my dash I have the tow button, do not have the hitch and do not have the BT mirrors....So for all looking for the answer...Can anyone list what makes a Titan a BT or Non-BT. Thanks in advance from all.
2008.5 SE CC 4X4 Smoke
Rear DVD Player
Added Chrome door handles
Fog Lights
More to come later
bigboytitan is offline   Reply With Quote
Old 03-12-2008, 09:47 AM   #22
Quartz
Quartz's Avatar
What did the window sticker say?
O6 4X2 Granite SE CC, Big Tow & SE Popular Pkg, Nissan bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension
Old 03-12-2008, 10:15 AM   #23
NorCal 4x4
NorCal 4x4's Avatar
2008.5 Tow Pkg.
Heavy-duty battery (710 CCA) — Standard on FFV models
Trailer brake pre-wiring
Additional 7-pin wiring harness
Lower final gear ratio (3.357:1); similar to a 4-speed automatic 4.10:1 ratio
Class IV receiver hitch
Tow hooks (standard on SE, PRO-4X, LE 4x4 models)
Extendable tow mirrors, (not available on XE).
Not part of the 2008.5 Tow Pkg.
Transmission temperature gauge, standard on 2008.5, non-tow Titans, (but not available on XE).
According to nissanusa.com
http://www.nissanusa.com/titan/speci...-crew-cab.html
Old 03-12-2008, 10:46 AM   #24
Howorks
So.. if I have the OR package, then then only thing I'm missing from the BT package is the mirrors and trans temp gauge?
I hope to be able to two 8-9K pounds of travel trailer without problems.
Where would I find the pre-wiring for trailer brakes?
Old 03-12-2008, 11:10 AM   #25
NorCal 4x4
NorCal 4x4's Avatar
For some reason the new Pro 4x non tow pkg Titan is rated at only 7,300 lbs, even though it has the same gears. IDK.
Personaly if I was going to tow 9000 lbs. very often, I'd get a 3/4 ton diesel, especially if mountain towing.
I'd add a tranny temp gauge though even for 7000 lbs.
I think the prewiring is only available with the tow pkg, so you could have that added ... when you buy a brake controler and have it installed.
Old 03-12-2008, 12:17 PM   #26
bigboytitan
Didn't say anything about the BT but it is the O/R package!
Old 03-20-2008, 04:39 PM   #27
havotec1
Hi all thanks for all of the good information. From this I have discovered I don't have the big tow, I do have the offroad package and the factory hitch, however I can't find the prewiring harness plug under the dash, so I guess my question is how would I go about wiring my brake controller. I was stoked because I bought the piggytail adapter from my dealer and had it wired to the controller, I thought I was almost done. Any help would be appreciated.
havotec1 is offline   Reply With Quote
Old 03-23-2008, 03:57 PM   #28
cooksj8
Hey, I am a little confused...I am not sure if I have the BT pckg or not. It is a 04 CC LE, and has the tow mirrors, the tranny guage, but on the sticker inside the door it says it has the 2.94 gear ratio. I thought that the BT has the 3.34 or whatever it is. Anyways any help would be great.
cooksj8 is offline   Reply With Quote
Old 03-23-2008, 07:00 PM   #29
loufish
loufish's Avatar
2004-2007 had a trans temp gauge if BT...IF those years don't have that gauge, then it's not BT.
Someone could add the mirrors, or hitch, but the gauge is the tell-tale...
If you have the Off-Road package, then you would have the same gears(3.337) as BT.
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
User Name
Password
getting a non tow package 2wd, what do i do? cnielsen4130 Titan General Discussion 16 05-10-2007 08:22 PM
should i get a tow package? bigblue35 Titan Suspension 10 01-11-2007 11:02 PM
Big Tow Package rogerhrt Titan Towing & Hauling 2 08-16-2006 12:12 PM
Tow package Ronald Titan FAQ & Howto Area 10 02-16-2005 12:30 PM
Are Popular Package and Utility Package Worth it? whistler Titan General Discussion 18 11-01-2004 06:07 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
