Old 02-18-2008, 08:34 PM   #1 (permalink)
Send a message via AIM to bagellord
Noob at towing and titans
I have an 08 Titan LE Crew Cab 2WD, and go camping fairly often with a small 2000LB trailer, and have a few questions. What gear do I need to be in and do I need to have tow mode on? Also, about the break in. I have 4k+ miles on my truck, but have not towed 500 miles at less than 50mph, do I have to do that still?
2008 Nissan Titan LE Crew Cab
Black/Black Leather
Tow Package
Black Brush Guard
Black Undercover Hard Tonneau Cover
Wish List:
Borla Exhaust
Cold Air Intake
Bullydog
World Peace
bagellord is offline   Reply With Quote
Old 02-18-2008, 08:43 PM   #2 (permalink)
Titan-ization's Avatar
Arrow Re: Noob at towing and titans
If you are only towing 2k lbs., then you are OK, you shouldn't have to have tow mode on, unless you are going through mountains or hills. If oyu are on flat ground, you are golden. Really all tow mode does is increase your RPM at lower speeds to put less strain on the engine when moving at low speeds and from a dead stop. As far as what gear, I usually tow in 4OD or straight 4th if I am in tow mode. With only 2k lbs. you aren't putting a whole lot of strain on the truck.
2005 Nissan Titan KC SE 4X2 Tow package, popular package, drop in bedliner, running boards, 2* advance, 18" wheels, Rear sonar, adjustable pedals, 6-disc in dash CD, full frontal brush guard, heated mirrors, head mounted driver info center, auto adjust rear view mirror, home link system, Flowmaster Super 44 hidden dual exhaust, Cobra LTD 29 40 channel CB with dual antennas, tool box w/ black diamond plate
Titan-ization is offline   Reply With Quote
Old 02-18-2008, 08:48 PM   #3 (permalink)
Geezus_Aach's Avatar
Send a message via AIM to Geezus_Aach Send a message via Yahoo to Geezus_Aach
all tow mode does is hold the gear (1, 2, 3 ) to a higher rpm, so it won't short shift.
...and all you are towing is 2k lbs. ..? no worries
NeW 2008 TiTaN Kc Se 4x4
born tues july 24, 2007 : adopted tues jan 01, 2008
Factory Options:
new Rockford Fosgate!, bed liner, bed extender
Accessories:
OEM rubber floormats
bug guard
window vents
chrome mirrors (non BT)
tint
Geezus_Aach is offline   Reply With Quote
Old 02-18-2008, 09:29 PM   #4 (permalink)
So if I am going to be going up and down hills what do I need to be in?
Black/Black Leather
Tow Package
Black Brush Guard
Wish List:
Borla Exhaust
Cold Air Intake
Bullydog
World Peace
Old 02-19-2008, 01:36 AM   #5 (permalink)
I would just keep it in 4th and turn on tow mode, should be good to go pulling only 2k lbs.
Old 02-19-2008, 04:48 AM   #6 (permalink)
Carbeaux's Avatar
Do you have the tow package? If you do, then towing that light, you can probably stay in fifth most of the time. Bump down to 4th if you notice the tranny temp start to climb. You're not pulling much, relatively speaking so you shouldn't have any problems whatsoever. As for break in, again, you're lightly towing. Just don't do any jackrabbit starts while hooked, take it easy. You're just allowing the diff gears to seat a little more deeply. Because you are towing light, I wouldn't worry too much about your speed. Just be safe since it's a new combo for you. I'd say stay around 60 mph and vary your speed, just like you did on your initial break in.
Hook 'Em Horns!
- Frank Zappa
Old 02-19-2008, 10:09 AM   #7 (permalink)
ok Thanx guys
Stupid iPod corrected it when I was checking at my grandparents apartment
Black/Black Leather
Tow Package
Black Brush Guard
Wish List:
Borla Exhaust
Cold Air Intake
Bullydog
World Peace
Old 02-20-2008, 09:24 AM   #8 (permalink)
To extend the original 2K lbs question - my trailer is 4K. It's mostly flat around here so I'm guessing 5th will be fine. 4th for hills (won't the transmission switch down)?
I don't expect Towmode until the summer when I head west to the mountains.
gksmith is offline   Reply With Quote
Old 02-21-2008, 10:27 PM   #9 (permalink)
loufish's Avatar
If you're towing around town, then hit the TM, it will help to keep you in 1,2 and 3 gear a little longer.
On the highway, the TM does nothing so don't worry about it.
You should manually downshift to 4th, or even 3rd if need be on hills. The trans will first un-lock the torque converter before downshifting to 4th gear, this will get the trans temp up. If it's a short hill, no big deal, but if it's a long grade then you do the downshifting...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 02-22-2008, 12:07 AM   #10 (permalink)
Wildmike's Avatar
I tow a 17' boat that weighs around 2200 lbs. I always leave it in D. I run about 70-75 on the freeway and the tranny only shifts down if it's a fairly steep grade. (more than 4%) I have never had the tranny heat up on the freeway. The only time it starts to heat up is pulling steep grades about 30-35 behind slow people on side roads. I think this happens because the tranny is out of lock-up.
WildMike
2006 4WD KC SE w/ BT
Fram Boost CAI
Custom 3" Magnaflow exhaust
http://media.putfile.com/Titan-0-85 2/15/06
http://media.putfile.com/Nissan-Titan-on-Dyno 8/17/07
Wildmike is offline   Reply With Quote
Noob Here ThorMotoX Titan General Discussion 18 06-01-2007 07:31 AM
Noob here Blue Thunder Titan General Discussion 14 03-29-2007 01:52 AM
Hid Noob eduardomi Titan Parts & Accessories 3 03-05-2007 07:09 AM
Putting the Titans towing ability to the test! NiteTrain Titan Towing & Hauling 3 10-23-2005 03:55 PM
Titans mods and towing question Cali_Titan-SE Titan Towing & Hauling 6 10-19-2005 03:48 PM
