Old 03-01-2008, 12:16 PM   #1 (permalink)
DrPlay's Avatar
Brak Controller Woes: Pt2
Ok-- so far hooked up after market harness to Nissan harness plugged it in AND all blinker, hazard, brake lights, runnig lights etc work on both trailer ad Titan. BUT even after turningthe truck lighs off, turnong the truckoff and taking out the key both car and trailer running lghts remain on!!! If I unplug traier from the truck the truck running light are still on. Will post mywire connections a bit latr have to go to daughters basketballgame right know. Any early ideas from you al would be appreciatd. Be back in 90 minutes.
BB
2008.5 Nissan Titan CC SE
2006 25' Airstream International CCD
2004 Honda VTX 1300C
DrPlay is offline   Reply With Quote
Old 03-01-2008, 02:33 PM   #2 (permalink)
Derwud's Avatar
Re: Brak Controller Woes: Pt2
Originally Posted by DrPlay
Ok-- so far hooked up after market harness to Nissan harness plugged it in BB
Does this mean you are using an aftermarket connector at the rear of the truck? Okay the problem is simple. You are getting battery power to your lights. Now how to figure out how and where it's happening..
E-Trailer help
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 03-01-2008, 03:29 PM   #3 (permalink)
DrPlay's Avatar
OK -- back from the game (and completed the post game honey-do list). I can slow down now and try not to make so many spelling errors.
Nothing going on at the rear. Have the tow package factory hitch big mirrors etc. The truck came with a Nissan wiring harness that connects under the left dash (the connection could not have been tucked up any higher nor any harder to find/grab). I needed the harness that snaps into the Prodigy and then connects to the colored wires of the Nissan harness. Went back to my Airstream dealer and they gave me one (free!! -- Colonlal Airstream, NJ).
Connected all the wires -- NOT by twisting them but with those male/female electrical connectors -- had help). Here are the connections I made.
Prodigy = 4 wires (black = +12 volt, red = stoplight, white = ground, blue = trailer brakes, brown = not available).
Nissan harness = 5 wires (red/green = break signal, black = ground, brown/white = break out, r/l = ill ((which by process of elimination must be the red wire with blue stripe)), red = fused B+).
How I connected: Prodigy black to Nissan red AND red/blue
Prodigy red to Nissan red/green
Prodigy blue to Nissan brown'white
Prodigy white to Nissan black
That's it!? And you know what happened. Anything jump out at anyone. Gonna take it to Airstream next. They hook these things up everyday.
Old 03-01-2008, 04:18 PM   #4 (permalink)
Derwud's Avatar
This doesn't have anything to do with your Brake Controller or wiring.. Try this.. Hook-up the trailer and then disconnect the brake controller at the factory connector and see if the lights stay on.
As I said before, the lights are getting a battery feed. You need to check the connector at the back of the truck and at the trailer..
Old 03-01-2008, 04:30 PM   #5 (permalink)
walleeme's Avatar
Brake controller wiring. Help!
Here is the thread that got me through my troubles.
My has almost nothing compared to some of you guys, but I still like it.
MADE IN USA is the way things are supposed to be.
ACCEPT NO SUBSTITUTES.
And if you have to, you have to.
Wallee AKA BaldWhore™
You know you had a great night last night when you make it home the next day missing at least 1/2 of your clothes.
walleeme is offline   Reply With Quote
Old 03-01-2008, 04:31 PM   #6 (permalink)
walleeme's Avatar
trailer brakes
And this too.
Old 03-01-2008, 05:27 PM   #7 (permalink)
DrPlay's Avatar
Derwood and Walleeme
Forgive me, despite being Piled Higher and Deeper (PhD) I'm a bit dense on this whole subject.
Walleeme -- I searched and am still confused.
Derwood -- is it possible that the illumination wire that i did connect is causing a problem?? Should I disconnect it? What do you mean by disconnecting at the "factory control"? Is that where the male/female connectors between the colored wires?
BB
Old 03-01-2008, 05:42 PM   #8 (permalink)
walleeme's Avatar
Red/Grey = Brake Signal
Black = Ground
Brown/White = Brake Out
Red/Blue = Illumanation (Not Needed)
Red = 12 volt fused
DOUBLE CHECK THESE! Carefully. I made a mistake when I did mine.
A wire out of whack will put you where you are.
Old 03-01-2008, 05:44 PM   #9 (permalink)
Derwud's Avatar
BB
Ooops a PhD, I'll talk slow for you.. My brother is also one of you, so I have had to do this before...
Wait, what did you connect the illumination wire too? That wire should have just been taped off.. If you look at the threads that Walleeme posted I gave a direct wire to wire conversion in one of them (It's in a word doc, if that helps)...
Old 03-01-2008, 05:44 PM   #10 (permalink)
walleeme's Avatar
http://www.titantalk.com/forums/118616-post13.html
Old 03-01-2008, 05:49 PM   #11 (permalink)
Derwud's Avatar
Nope... Man you PhD's need a normal brained person to follow you around..
Old 03-01-2008, 05:52 PM   #12 (permalink)
DrPlay's Avatar
LOL -- I'll disconnect the illumination wire (I connected it with the Nissan red to the Prodigy black -- so I actually have two Nissan wires connected to the Prodigy black) -- don't ask.
I'll report to the 2 professors tomorrow. Thanks and good-night Doctors of Titanology.
Old 03-01-2008, 06:27 PM   #13 (permalink)
Derwud's Avatar
I hope this doc can help you out...
Old 03-01-2008, 07:10 PM   #14 (permalink)
walleeme's Avatar
Umm.
I didn't mention it, but I have a PHD too.
Honorary.
I really like my truck.
Towing champ.
Old 03-01-2008, 07:38 PM   #15 (permalink)
anmut's Avatar
I think you have your ground and your main brake power reversed?
Mods: Bully Dog Tuner · 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow
Nissan OEM Brush Guard · Hellwig Traction Springs · 4 Hella 500FF OR Lights · Line-X Bed Liner · Jason Topper
Wish List: Nerf Bars · Tires · Rims
Waiting For Support On: TruTrac
"I can't find anyone to race..."
anmut is offline   Reply With Quote
HID woes UWSkier Titan General Discussion 9 03-20-2007 10:39 AM
Big Brak options are on the way Todd TCE Titan Wheels, Tires & Brakes 12 12-27-2006 06:26 PM
Titan Woes!! HyperSportRacing Titan General Discussion 10 09-08-2006 08:26 PM
rear end woes PuvMan Titan General Discussion 1 06-12-2006 08:22 AM
Bed liner woes Doghouse
