Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
No brake lights or turn signals on trailer - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-12-2008, 09:00 PM   #16
loufish
loufish's Avatar
Re: No brake lights or turn signals on trailer
This type of issue comes up ALOT...
If you had lights and now you don't, you need to use a test light to check the pins at the factory 7 pin connector first!
If have the lights at the connector, then it's the trailer...Many times a trailer will have a bad ground and then try to seek ground thru the trailer ball and hitch...so it doesn't work on your truck, but it works fine on your buddys truck...you buddy got a better ground thru his ball then yours...
Other then missing relays, 90% of the time it's the trailer...
BTW...The Titan IS setup to light up American style trailers, so a 7-4 pin adapter should work fine, the truck it's self is different, but the tow circut is all USA style...
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
Old 03-12-2008, 10:12 PM   #17
Jerrygfd
Jerrygfd's Avatar
Don't spend $600, Nissan is over charging for soemthing that should cost less than $100. I had similar problems when I hooked up a boat, then none pulling a utility trailer. I rewired the boat and trailer but the problem was the trailer recepticle on my truck that Nissan had to replace. Fortunately my truck was still under warranty then.
2004 Smoke Color SE 4 X 4 Crewcab fully loaded with Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg, SplashGuards, Floor Mats,
I installed after purchase: *Dealer installation
Bug Deflector,
Wade Window Vent Visors
Westin Platinum Step Rails
Carriage Bolt Billet Grilles Upper and Lower
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Husky rear floor mats
TruxedoTonneau Lo Pro Cover
Prodigy Brake Controller
IPOD Interface Kit
Firestone Ride Rite Air Bags part #2355
Towing on vacations: 2008 Keystone Hideout 28'
Model 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
DR Rear shocks
Future Mods: Front SAWs coilovers or Bilstein Adjustables
Jerrygfd is offline   Reply With Quote
Old 03-15-2008, 01:25 PM   #18
young dank
Originally Posted by young dank
if you are hooking up to a 4- pin trailer, Nissan has an independent lighting system for their turn signals and brake lights. But trailers rely on american made vehicles that the brake and turn signals work together on one bulb. you need a 3 wire to 2 wire power converter so that you can combine the brake and turn signals. no higher than 15 milliamps or you will void your warranty and mess up your electical system. I have same problem with my boat. 7 pin to 4 pin adapter doesn't solve my problems. need a converter. I haven't installed one on mine to be absolutely sure but it says that's what ya need in the manual under towing.
this is wrong, ended up being a bad ground. I ran my white wire ground on my boat all the way to the light and grounded on the bolt that holds the light in place, everything works.
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
young dank is offline   Reply With Quote
Old 03-15-2008, 07:58 PM   #19
loufish
loufish's Avatar
Thanks!....I'm digin' my truck and its got over 55,000 miles...
Old 03-15-2008, 10:49 PM   #20
1bigwhitetruck
1bigwhitetruck's Avatar
My 05 titan had the same problem with trailer lighting. Dealer said that I had a recall. They installed a bcm sub harness that has inline fuses to the turn signal wires. Told me everything now works fine. Well plugged into a trailer and the lights still did not work. Got a buddy that works for an infinity dealer to pull a wire diagram for me and we found out that the bcm was not sending a signal out to the turn signal for the trailer. The truck turn signals worked fine, but had no trailer. Took it to the dealer and got the run around about how my trailer is causing my problem and that I should get my trailer rewired to the vehicle. My trailer works on my 07 titan but not my 05. So I pulled my trailer down to the dealer (me knowing that it needs a bcm) and told them to figure it out. Rewire the trailer to the vehicle if it needes it and if it works I will pay whatever. The tech actually rewired the trailer and the lights still did not work (no surprise). I called the service manager and arranged a meeting to discuss my lighting isssue. Met with the manager and explaned to him what was going on and that I had an infinity mechanic inspect my bcm and found out it was bad. He called in the writer and the tech. The writer and the tech sat there and told me to my face that the bcm is functioning normal. That my problem was in the trailer. Had them plug the trailer into another titan in front of me and the manager and it worked fine. Plugged it into my truck and it don't work. Service manager go very upset that it had gotten to this and replaced the bcm for me for free. If you want I can get the wire diagram for your truck and you can test the two wires and see if you have output.
2007 Nissan Titan CC 4x4 LE, -Daily Driver. Nismo CAI, PowerAid tb spacer, 2 degree advance, 2" Ready lift front kit 1" rear blocks, 35x12.50r18 Toyo open country m/t.
2005 Nissan Titan KC 4x4 Off-Road, -Not so daily driver. Stillen supercharger (3rd motor currently broken), AEM CAI, Custom tb spacer, 2 degree advance, Jba Headers, No cats, 3" straight pipe, 5" RBP tips, true dual exhaust, Pro-comp 6" stage 1 lift, Daystar 2" spacers, 3" custom body lift, Custom rear springs, Modified dana 60 rear axle w/4.88 gears, Modified front GM diff w/4.88 gears, 38.5x12.50r18 Pro-Comp Xterrain. Bare foot gas pedal (one day I will actually fix it and be able to drive it again)
1bigwhitetruck is offline   Reply With Quote
Old 03-16-2008, 02:05 PM   #21
mytitan
ok ive tried running the ground wire all the way to the lt rear trailer, and no results. ive also check all my fuses and relays and i have all of them working properly. i still have no lt and lt break light. im leaving tomorrow on a camping trip. what i can do temporarily to get left lt and brake lts.
please help.
mytitan is online now   Reply With Quote
Old 03-16-2008, 04:44 PM   #22
vegastitan21
vegastitan21's Avatar
i have a trailer lighting problem but its a lil different. i have no running lights and only my lef hand brake and turnsignal works. could it be the same thing? the trucks going into nissan tommorow since i was under the truck yesterday messing with the trailer connector to find out my right side of my differential and brake rotor shield covered in oil.
Banks Exhaust
2* timing advance
K&N drop in with air box mod
Helix TBS
H.I.D. 10000k conversion
Smoked Tails
Glassworks fenders
2.5 leveling kit
CST 4 inch spindle
35/12.50/17 BFG A/Ts
Eagle Alloys imitation beadlocks
5% tint all around 35% entire windshield
2 MTX 10s
vegastitan21 is offline   Reply With Quote
Old 03-16-2008, 07:14 PM   #23
young dank
please help.
you must be missing a blue relay for the left side because if the right side works but the left doesn't, you are miss some power. look at your fuse box again under the hood behind the battery and make sure you have two blue relays. look at the diagram to make sure you are lookin at it correctly. there should be a relay on all those connections. and the fuses beside them should be checked. let me know what happens. wish I was there to help you cause I can fix anything on a Titan and I am shocked that it isn't a missin relay.
Old 03-16-2008, 07:17 PM   #24
young dank
tell them to check your relays under the hood and see if you got fire in your 7 pin plug. make them verify in front of you. These trucks are better than anything out there. Nissan doesn't train the techs at the dealership good of our changes we make to them.
Old 03-16-2008, 08:10 PM   #25
mytitan
i only have 1 blue relay, the rest are all brown. tow#1 has a blue relay and tow #2 has a brown relay. my bro's armada has the same thing.
Old 03-16-2008, 08:56 PM   #26
young dank
impossible, the lh and rh relays should be the same color and the tow relay is brown for the break controller. is your truck equiped with a vdc and other stuff or is it an XE. but trailer lights are controlled by two BLUE relays. trust me, I know the exact part numbers, I work there. If you are facing your trucks hood. from left to right, brown tow relay. directly behind it from left to right two blue relays, LH and RH. read your fuse box. plus I don't think those relay will go bad. put a tester on your 7 pin plug in rear and ground it to the ground pin or the bumper if its chrome and turn on head lights and hazard lights and see if you get fire.
Old 03-16-2008, 08:57 PM   #27
young dank
and just a wild guess, but I think you missin one blue relay for the LH plug in your fuse box.
Old 03-16-2008, 09:01 PM   #28
young dank
oh MYTITAN, you have an '05, you only have 1 blue relay. its your trailer dawg. test your pins, but I think its your trailer. cause one relay controls both lights. you might need to rewire the left side due too a short. or ground it better. the frame might be rusted. what kind of trailer is it?
User Name
Password
lt & rt turn signals mytitan Titan Towing & Hauling 7 03-16-2008 09:05 PM
No left turn signals...Help! MA-titan Titan Problems & Dealer Service 3 03-12-2008 07:37 PM
My Brake lights wont turn off??? 54warrior Off-Topic Discussion 2 01-26-2008 06:40 AM
no rh brake or turn on small trailer donlloy Titan Towing & Hauling 7 10-16-2006 10:11 AM
fixed problem no rh or lh trailer brake or turn donlloy Titan Towing & Hauling 0 10-15-2006 01:40 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
