Re: Think i can do this?
Originally Posted by Guiseppe
If it is a standard pallet, it probably won't fit in the bed because of the wheel wells, I maybe wrong, it will be off by 1-2 inches.
Standard pallets fit between the wheel wells.
Originally Posted by Peytons_Titan08
i will strap it down so if that does happen i dont get killed.
What's more likely to happen is it will slide forward & dent the front of your bed out into the cab. That happened to a co-workers truck hauling a pallet of tile.
'08 Titan SE, Crew Cab, 4wd, LWB, Smoke
