Old 03-06-2008, 07:50 PM   #1 (permalink)
Same ol' left signal/trailer light issue
Hey folks,
Someone give me the quick answer again on how to fix the Titan left signal/break light woes when hooking up to my trailer.
1st. Its Not the relays, or any fuses that I can immediately see.
2nd. I've seen this question before, but no definative answer.
3rd. Last thread in 2006? mentioned fuses under drivers side dash left or right of steering wheel.
My Titan worked fine with trailer last week, and little brothers chevy works fine with trailer now...so its NOT a trailer issue either.
ITS SOMETHING WITH MY 04 TITAN (only the left hand side back to the trailer.)
Thanks in advance for the someone with the quick answer and fix.
NOHEARTBEAT is offline   Reply With Quote
Old 03-06-2008, 09:11 PM   #2 (permalink)
Re: Same ol' left signal/trailer light issue
I can remember the name of the harness but there is a harness that has been recalled on certain trucks. There is a fuse in the harness for the left trailer lights, fuse blows on occasion and lights fail
predator176 is offline   Reply With Quote
Old 03-07-2008, 06:46 PM   #3 (permalink)
AZTITAN78's Avatar
I believe it was the BCM harness that was on the Recall.
AZTITAN78 is offline   Reply With Quote
Old 03-12-2008, 08:42 PM   #4 (permalink)
BCM recall. put a test light on the pins and turn lights on and check them
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
young dank is offline   Reply With Quote
Old 03-12-2008, 09:47 PM   #5 (permalink)
loufish's Avatar
The BCM controls left/right trailer signals...
Here's the scematics for the trailer/exterior lights:
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Trailer Left Turn Signal/left brake light not working bclmread Titan Towing & Hauling 60 04-06-2008 05:43 AM
Trailer right turn signal problem Txsbigfoot Titan Towing & Hauling 5 08-13-2007 09:57 AM
Trailer Brake, Signal Light fuse Help?!? Old Speed Titan General Discussion 3 04-11-2007 10:39 PM
trailer rt turnn signal inop mytitan Titan Towing & Hauling 9 02-25-2007 01:51 PM
Another Trailer Lighting Issue speedfrk Titan Towing & Hauling 3 10-21-2006 01:59 PM
