Old 01-22-2008, 10:04 PM   #1 (permalink)
Masa's Avatar
Smile First Time Travel Trailer Towing
Well, I have hauled small utility trailers before with my Titan. They were small enough that they did not require a brake controller. This month, I rented a travel trailer for the first time and hauled it behind my Titan. I first installed my Tekonsha Prodigy according to some of the suggestions here. I ended up installing it near my right knee. Drilled holes to the metal frame behind the dash and added a strip of thick rubber piece before installing the mounting bracket so that I can gain a slight angle and space to get to the switch and knob on the controller. I had to make a quick run to Lowe's because the mounting screws were a tad too short. I spent $12 on ready-to-connect wiring harness for Prodigy/Titan. It seemed well worth the money.
I rented the trailer for 2 nights and 3 days just to get acquainted with travel-trailering. Overall, I am happy to say that things went very smoothly for the first time. The rental travel trailer was Homestead 292BHS by Starcraft, which was practically new. It is supposed to be 6,444 lbs unloaded with GVWR of 8,500 lbs. The hitch weight is supposedly 849 lbs. I opted to rent a weight-distribution hitch (Reese) for $35. I was a little disappointed by the fact that I had to remove my White Knight backup lights in order to use the hitch. We had 3 adults, 2 little girls, an 80lb-dog and some gears plus the fresh water tank full of water (it was already filled up when I picked up the trailer). Except for the people everything was loaded in the trailer. We drove 400 miles and stayed at 2 RV parks. The most frustrating thing during this mini-vacation was to keep the speed under 50 mph per the owner’s manual’s break-in procedure. It was so easy to forget about pushing the tow mode button and disengaging the OD every time I restated the engine… I wished that the tow mode remains engaged even when you shut off and restart the engine. I recall that there is something you can buy to accomplish this, but I don’t tow often enough to make this mod. Better yet, wouldn’t it be nice if the tow mode not only memorizes the setting until manually turned off, but it offered 2 different modes. Tow mode 1 being OD automatically disengaged. Tow mode 2 being OD enabled.
It was a good learning experience and fun. Oh, kids liked the bunk beds. I think it will be more fun on a longer vacation and after the towing break-in is finished.
Now, I am wondering if I should replace the differential fluid even though I probably have about 6,000 miles since the last change. Anyway, we plan on renting it again this spring or summer.
'06 White 4x2 CC LE w/ Big Tow & Bench Seat
San Antonio, Texas
Masa is offline   Reply With Quote
Old 01-23-2008, 05:02 AM   #2 (permalink)
loufish's Avatar
Re: First Time Travel Trailer Towing
Glad you had a good time and a good expeirence.
Just to let you know, that's a lot of trailer for the Titan when it's going to be loaded up.
You didn't mention if there where any major grades to be clinbed during your trip, or if there where any issues with hi trans temps.
You should be towing if 4th gear...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 01-23-2008, 09:00 AM   #3 (permalink)
BuckyBadger's Avatar
Whats it run to rent something like that?
2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06
FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
BuckyBadger is offline   Reply With Quote
Old 01-23-2008, 10:37 AM   #4 (permalink)
Masa's Avatar
No major grades and the transmission temp stayed in the middle. Luckily every time I forgot about tow mode & getting gear out of OD, it was only a minute or so wafter e started driving when I rememberd or my wife reminded me about it!
San Antonio, Texas
Old 01-23-2008, 10:47 AM   #5 (permalink)
Masa's Avatar
Standard rate for renting this trailer was $100/day with minimum 3-night, 4-day rental. Because we only rented for 2 nights, they tacked on $25 charge per day. So, it was $125 per day for us plus what we paid to stay at the RV park.
It seems to me that if you are going to use a travel trailer for occaisional vacationing, you are far better off financially if your rent instead of buying one. I see tons of travel trailers around here parked at storage facilities most of the time, incurring storage fee, insurance premium, payment for the trailer when they mostly sit around... Not to mention time and money you spend on maintenance.
San Antonio, Texas
Old 01-23-2008, 12:52 PM   #6 (permalink)
CoachBoone's Avatar
That's a good question, whether or not to change the diff. I only did mine after our first big tow because we burned up the oem dino oil and had to take it to the dealer to inspect. After changing to synthetic and putting the alum finned cover on, I've had no worries. But with a first tow, you may have some initial wearing that might call for a fluid change. See if any experts chime in.
Glad you had a good time. Towing with the Titan is a treat because it pulls so easily and it handles so well. Hope this turns into a regular family outing for you. We've been doing it since summer of 04, right after I got the beast, and it's by far my favorite way to vacation.
Enjoy!
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 01-23-2008, 02:09 PM   #7 (permalink)
Yeah that tow made button is really in a place.
Old 01-23-2008, 05:21 PM   #8 (permalink)
Shane06fl's Avatar
The tow mode doesn't keep the trany from shifting in to OD. It only holds the lower gears longer so you can get up to speed.
OD is nothing more than the TQ converter locking up in 5th gear. The TQ converter locks in 4th also. Pulling a TT that size you need to stay in 4th gear or you should anyways.
If you ever decide to buy a TT buy used you can get a great deal on slightly used TT's. If you have kids look at the Keystone Hornets. The 24RB ( I think) has rear slide out in the back and 4 bunks up front. great floor plan for a family.
Sorry they changed the floor plan of the Hornet 24RB and gave it to the Pass Port. I have the Hornet 24RB but is has the exact floor plan as this one i linked to. BTW it opens to 30ft and is a breeze to pull with the Titan
http://keystone-passport.com/?page=d...08&model=240QS
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 01-23-2008, 08:35 PM   #9 (permalink)
loufish's Avatar
Sure you don't want to try that again...?
Drive(5th gear) IS the overdrive gear in the Titan's trans mission, has nothing to do with the converter locking up...
Born 9/2004
2002 Honda XR650R
Old 01-25-2008, 09:19 PM   #10 (permalink)
Shane06fl's Avatar
loufish your right, according to the gear ratio of the trany it would be a OD gear. It's very close to fourth and that would explain only a 250 RPM difference between 4th and 5th and huge difference when the TQ conv locks up. But these transmissions don't use the traditional OD with the planetary gears locking up do they? It seems like the TQ conv is doing the OD work.
2004 - 2007 Nissan Titan
Automatic Transmission
Type
Trans Model
RE5R05A
First 3.827
Second 2.386
Third 1.519
Fourth 1.00
Fifth 0.834
At any rate heavy towing in 5th is no good. The heaviest I tow in 5th and have no issues with ''hunting gears'' is about 3500 pounds.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 01-26-2008, 03:03 AM   #11 (permalink)
loufish's Avatar
Oh it's still a set of planetary gears, but yes the converter is "working". By working I mean it's not either locked up or unlocked, the PCM can very the lock-up (in percent) from say 60% to 100% and anywhere in between, so the converter has the last say...
Born 9/2004
2002 Honda XR650R
Old 03-04-2008, 05:41 PM   #12 (permalink)
Jerrygfd's Avatar
I just bought the 2008 Hornet Hideout 27B my first TT, an upgrade from a Coleman Destiny II Popup Tent Camper. I'm having a sway bar and Prodigy Brake Controller installed tomorrow and due a walk through inspection with the RV dealer the next day. We like this TT and my family is looking forward to our camping adventures, the next being Yellowstone this summer this time in style. My son (13) has seen the trailer and loves it and my daughter (15) has only looked at the brochure but is very excited. I case you can say anything is better when upgrading from a popup but mine is still great for a 1995 model. This TT seemed well built and fully configured and quite suitable pulling with my Titan. I can't say how that will be for another couple of days but looking forward to it. Have you had any problems with your model?
2004 Smoke Color SE 4 X 4 Crewcab fully loaded with Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg, SplashGuards, Floor Mats,
I installed after purchase: *Dealer installation
Bug Deflector,
Wade Window Vent Visors
Westin Platinum Step Rails
Carriage Bolt Billet Grilles Upper and Lower
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Husky rear floor mats
TruxedoTonneau Lo Pro Cover
IPOD Interface Kit
Firestone Ride Rite Air Bags part #2355
Towing on vacations: 2008 Keystone Hideout 28'
Model 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
Icon Rear shocks
Bilstein HD Front Shocks
Jerrygfd is offline   Reply With Quote
Old 03-04-2008, 06:04 PM   #13 (permalink)
I tow a couple of jet skis around Florida.
Should I be towing in 4th gear? or tow mode?
skimp0211 is offline   Reply With Quote
Old 03-04-2008, 06:11 PM   #14 (permalink)
yamatitan's Avatar
jet skis are extremely light compared to a travel trailer. Just put her in drive and go. If you have a tranny temp gauge than i would monitor it but you shouldnt have any problems.
Procomp 6" ($1300.00)
35x12.5x18 Toyo MT's $1100.00)
PRG Offroad Traction Bars ($489.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
SAW coilovers ($1000.00)
Bushwacker Pocket style flares ($600.00)
Rear Sway-away piggybacks ($399)
Money wasted so far=$9073.00
Old 03-04-2008, 06:48 PM   #15 (permalink)
Nissanloyalist's Avatar
Now, I am wondering if I should replace the differential fluid even though I probably have about 6,000 miles since the last change. Anyway, we plan on renting it again this spring or summer.[/quote]
If you have had the synthetic 75w-140 then there should be no worries. If you have the factory dino (assuming you have an 04) then yes change to a good quality synthetic. I use the Amsoil Severe Gear and like it very much. As far as others are saying to tow in 4th I totally agree with them. If you do find your self "hunting" gears the put it in thrid. It will keep the temps down as well. These trucks can run at high RPM's w/o worries. As far as the tow mode. I believe it will just hold 1st thru 3rd only a little longer and Nissan states this is to make the transmision feel as if you are not towing ( as far as shift points). I'm glad to hear you had a good experience. Rving is an addicting habit.
04 CC SE Smoke 4x4 DVD OR BT. AEM Brute Force CAI, Magnaflow Muffler, 2* Advance, Fitch Fuel Catalyst, Firestone Airbags, Mag-Hytech Diff cover, Stillen front & rear sway bar. Stainless rocker panels. Pull-Rite 12k and Prodigy controller for the 2007 Cougar 278RKS. Amsoil throughout!
Nissanloyalist is offline   Reply With Quote
Towing Jayco Eagle 314bhds Travel Trailer Safely bmmendez Titan Towing & Hauling 18 06-23-2008 08:33 AM
LT Tire Recommendations for towing Travel Trailer happenin-dad Titan Wheels, Tires & Brakes 10 02-10-2007 07:43 PM
Towing a 7000 lb travel trailer mtofell Titan General Discussion 14 12-07-2006 09:09 AM
Travel Trailer towing + ? Tom-ADC Titan Towing & Hauling 21 08-20-2004 10:02 PM
Towing travel trailer - first time Titan Ken Titan Towing & Hauling 0 06-17-2004 10:03 PM
