Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Mods to Safely Upgrade Towing Capacity? - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 05-06-2008, 03:07 PM   #46
albonismo
albonismo's Avatar
Send a message via MSN to albonismo
Re: Mods to Safely Upgrade Towing Capacity?
tell ur wife if she wants that big ol TT, then you demand a new truck! if i were you, i wouldnt risk safety for anything.
'06 Smoke XE CC
Mods: Black Westin Bull Bar, AEM Bruteforce Intake, 6CD MP3 in dash player, Stillen Dual Rear Exhaust, ReadyLift 2" Leveling, OEM Trailer Hitch, LE rims, BFG AT KO 305/65r18
Future Mods: Detroit TruTrac, Fender Flares
Gezuar Pavaresia!
albonismo is offline   Reply With Quote
Old 05-07-2008, 10:07 AM   #47
jschikore
Thanks for the useful info!
2 Questions: What is the stock gear ration the XE comes with?
What ratio would I need to upgrade to to maximize the towing capacity?
jschikore is offline   Reply With Quote
Old 05-07-2008, 12:44 PM   #48
HudsonValleyTitan
HudsonValleyTitan's Avatar
Stock non-tow gearing is 2.94:1 VS the tow packages 3.36:1
- Joe
NEW - 2008 Blizzard Titan CC PRO-4X OFF ROAD LWB w/TOW, UB & RF pkgs w/XM & Bluetooth handsfree phone system, Nissan bug deflector, Under seat storage box, Nissan factory step rails, LED taillights, Line Of Fire LED Light Bar, Chrome Door Handles, TomTom GO 700 GPS, Extang Tuff Tonno.
Old 05-08-2008, 08:02 AM   #49
hstiny
The only way to make the Titian safe to pull that length is to cut the frame and weld an extension on so that you could have a longer whell base. I have a 30 ft. Sandpiper with simular weights and have a dual cam wt dist. system. Have not been able to get sway out no matter what. I was like you and thought only of weight to pull and not length. No matter what mods you do, it will not be safe.
hstiny is offline   Reply With Quote
Old 05-08-2008, 10:31 AM   #50
HudsonValleyTitan
Originally Posted by SAMSAR
Assume for a moment that money isn't the issue...
My wife has fixated on a specific Travel Trailer she likes and I'm trying to see if there is a way I can safely tow it without buying a new truck. I would buy a 250/350 type truck but am having a hard time justifying it for only a dozen towing days a year and would be overkill any other time.
My 2007 CC came with every option I could select and has been fine for the snowmobiles/motorcycles but now I'm starting to push the limits of the truck.
The TT we are considering is the 2008 Jayco Jay Flight G2 32BHDS. Sorry, I'm not able to post a URL for you as I have too few posts on record. Here are the key stats though:
Gross Vehicle Weight (lbs.) 9,750
Unloaded Vehicle Weight (lbs.) 7,855
Cargo Carrying Capacity (lbs.) 1,895
Dry Hitch Weight (lbs.) 920
Exterior Length 35' 6"
Exterior Height with A/C 13' 4"
Fresh Water Capacity (gals.) includes water heater 46
Gray Wastewater Capacity (gals.) 32.5
Toilet/Black Wastewater Capacity (gals.) 32.5
In the cab would be 2 adults/kids/dogs. I don't have to bring firewood with me while towing and can drain the tanks before I tow. We live in the northeast so while mountains exist, we're not talking the Rockies.
In reading through previous posts, I've identified the following possibilities to safely increase towing capacity:
Prodigy Brake Controller
Equilizer Trailer Hitch
Firestone Airbags
Stillen Front/Rear Swaybars
AEM Bruteforce Cold Air Intake
Magnaflow Muffler
2 Degree Timing Advance
Tires: ?
Brakes: ?
Rotors: ?
Shocks: ?
Anything Else?
By doing these things and anything else you recommend:
What capacity would I gain by reinforcing the truck.
What will I not be able to solve for?
Thanks!
Paul
It's been a while now, did you buy a TT yet? I was going to say...with only 2 kids, maybe a smaller TT is a better idea...especially if you're not used to towing that big with your truck. I have the 31 BHS that's 32'6" long and it tows fine but also now have a longbed Titan. I'm at what I concider to be the longest TT that should be attempted with this truck. The 26 or 28 BHS may be more sensible...unless your wife is like mine. In that case, you'll have to do whatever she says! lol.
Old 05-08-2008, 01:36 PM   #51
Rntmake3
Rntmake3's Avatar
I hope you did not buy a trailer that size. Shame on your dealer if you did. I am a dealer and I pull all sizes everyday. I have pulled trailers that dry weight close or more that what you are looking at....and it will control your truck. I would suggest to stay below 30ft or no more than 30ft with all half ton trucks...look these trailers will eat the new Tundra as well so it is not a MACHO contest weight distribution hitch just levels the towing and even with dual sways which I don't recommend the trailer weights so much more than your truck. If the trailer starts swaying you are going with it..period.
"I have pulled a lot, actually a whole lot..of rvs..literally."
2004 Nissan Titan SE CC NISMO 4x4 Off-Road
Air-Raid cold air intake and throttle body, Magna-Flow cat-back duals, Unichip Programer with handheld, billet replacement grills.
Rntmake3 is offline   Reply With Quote
User Name
Password
05 Towing Capacity? Towing to Central Mexico Invictusklt Titan Towing & Hauling 3 08-04-2007 12:36 PM
towing capacity 5.9fan Titan Engine, Transmission & Drivetrain 10 07-24-2007 06:26 PM
Towing capacity Just-in Titan Towing & Hauling 7 01-02-2007 04:50 PM
Towing Jayco Eagle 314bhds Travel Trailer Safely bmmendez Titan Towing & Hauling 14 06-11-2006 09:09 PM
Towing Capacity without Big Tow Socal58 Titan General Discussion 2 02-15-2004 10:25 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
