Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Cargo Trailer Size and Truck Add-ons - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-17-2008, 08:15 PM   #1
PatrickL
PatrickL's Avatar
I am just about ready to get a Cargo Trailer to haul up the AlCan at the end of April. Probably around 7K or more weight. The very minimum is a 7x14 flat nose but I would prefer a v-nose if possible. They haul better and save a little fuel. It all counts when running 3500 miles.
V-nose typically come in 20-25ft models. What do you guys think about hauling this length? I would prefer a 20ft just to keep it easier. Is it that big a difference. Also what brands? I was looking at interstate but TNT's are alot cheaper. I will sell it once getting to AK as I don't need it but for the move.
More importantly. I was thinking for sure I need a weight distribution hitch. How much, which brand and why? They all seem pretty much the same idea in the end. Also, I am on a tight budget. Break controller, Prodigy seems to be the concensus here so that's solid. What about airbags to level her out? Do I even need these if I have a weight distribution hitch?
Thanks in advance for the help.
But I'd rather have a Titan.....just got a 2008.5 Pro-4x and love it.
PatrickL is offline   Reply With Quote
Old 03-17-2008, 08:33 PM   #2
loufish
loufish's Avatar
Re: Cargo Trailer Size and Truck Add-ons
The 20 footer would be more enjoyable to tow...anything over about 4000 lbs should use a WD hitch...
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
Old 03-17-2008, 08:35 PM   #3
loufish
loufish's Avatar
For the WD's other will need to chime in, when I've tow with a WD it's been borrowed, so I had no choice...
For brake controller, I do highly suggest the Prodigy.
Old 03-17-2008, 09:09 PM   #4
Carbeaux
Carbeaux's Avatar
If you're sitting on the stock suspension, you probably won't need to worry about leveling it much. The factory rake will take care of it for you. If you're on a level kit (PRG, NCD, etc.) then you might want to consider bags to keep it level when you're hooked up. It will just depend on your tongue weight. I have the Reese and tow about 6500 at most and it seems sufficient. I do get a bit of tail wagging, but I'm at 27 feet and I'm guessing that will make a difference too.
Hook 'Em Horns!
- Frank Zappa
Old 03-18-2008, 06:53 AM   #5
PatrickL
PatrickL's Avatar
I actually have a 2008.5 which comes level from the factory so it sounds like some air bags might be in order. Any recommendations?
Old 03-18-2008, 06:05 PM   #6
ORTitan
ORTitan's Avatar
I towed over 5k miles last year with my 8.5x20 enclosed hauler.The trailer scales at 9xxx lbs ( of course I am within the towing limit ). I have the small Firestone bags and highly recommend them they will level out the truck nice when loaded and aren't too harsh of a ride. You will really also want to use the weight dist hitch to get some weight back onto the front axle of the truck. I have 1200 lb bars on mine. In hindsight I would have bought a longer trailer, a 24', instead of the 20'. I have towed both lengths several thousand miles a year and you just don't notice the difference in length going down the road. Occasionally you will notice the difference in tight maneuvering, but this is not a deal breaker. Prodigy controllers are very nice, no problems with mine.
Click image for larger version
2005 Radiant Silver 4x4 Big Tow SE KC Banks Monster Exhaust
Dog's love trucks! Taiga dog poses with his two Titans at his biscuit buddies Nissan dealership
ORTitan is offline   Reply With Quote
Old 03-19-2008, 06:34 AM   #7
PatrickL
PatrickL's Avatar
Looks like those airbags work well. Your truck doesn't even look like the trailers attached its so level. Is there much difference in the weight dist hitches out there or are they pretty much the same? Pretty expensive piece of equipment.
Old 03-19-2008, 08:21 PM   #8
ORTitan
ORTitan's Avatar
Just stick with a good name brand Eazy-Lift, Reese, Etc. I think my whole hitch setup was only $200 something. Good Luck.
Old 03-19-2008, 08:49 PM   #9
mjtech12
mjtech12's Avatar
If he got his weight dist hitch for $200.00 thats a phenonemal deal
Here is the Hitch I use on a 31Ft Travel Trailer At 6500Lbs Dry
Strait-Line Weight Distribution Trunnion Bar Kit (1,200 lb) with Hitch Bar
Sway Control Built In
Reese Has This on Sale $635.95 Free Shipping
Regularly Priced At $953.90
This Reese 1,200 lb Strait-Line Weight Distribution Hitch Kit consists of a patented Dual Cam High-Performance Sway Control and a High-Performance Weight Distribution System in one easy-to-install package. It is the ultimate hitch in detail and by design. This hitch gives the driver complete control at a reasonable price. Good Luck
P.S. If your truck is at its level state don't use air bags they will cause your truck and trailer to have more sway
2008.5 Titan XE
Perferred Package
BT Package
18" Wheels
mjtech12 is offline   Reply With Quote
Old 03-20-2008, 10:57 AM   #10
PatrickL
PatrickL's Avatar
I have a 2008.5 that comes level from the factory. Are you only talking about those people who put on a leveling kit or also trucks like mine?
Old 03-20-2008, 12:34 PM   #11
BK19702
BK19702's Avatar
You're still running a stock suspension, so you should be ok. The difference would be with an aftermarket leveling kit like the ones previously mentioned earlier.
This is a good WD hitch:
http://rvwholesalers.com/catalog/pro...cat=364&page=1
Couple that with a Prodigy brake controller also.
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 03-20-2008, 12:38 PM   #12
BK19702
BK19702's Avatar
Did you mean the class IV receiver? If you got the entire WD setup for $200, that's some deal indeed.
CourtesyParts offers the class IV receiver, relays, pin connector for $211, which is a nice little package in it's own right. The WD system is $350+ on it's own, hence the confusion by your post.
Old 03-24-2008, 04:57 PM   #13
ORTitan
ORTitan's Avatar
My truck is a BT model, so it had the receiver installed already. As for the WD hitch, it came with a long drop stinger and weight bars, no anti-sway bars. I purchased the hitch and Prodigy brake controller from the people I bought my trailer from.
User Name
Password
What size tire will fit my truck cisco Titan Suspension 5 07-01-2007 08:39 PM
Equal-i-zer Hitch Shank size & Outback Trailer woodside Titan Towing & Hauling 0 05-30-2007 01:40 PM
6X12 enclosed cargo trailer for sale in OC, CA rcantu Buy/Sell 8 09-19-2006 10:56 PM
When will there be an AWD full size truck? mtofell Titan General Discussion 24 01-12-2006 11:45 PM
What size drop nedded for trailer hitch? waitingfortitan Titan Towing & Hauling 6 03-23-2004 12:26 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
