Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
2wd Boat Towing - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-18-2008, 08:36 AM   #1
PhiLambTitan
PhiLambTitan's Avatar
2wd Boat Towing
Okay spring break is around the corner and a couple buddies just invested in a boat w/ no truck go figure. I have a 04 2wd LE w/ big tow and will be towing the 17' ski boat. I never towed a boat of this size before just a small aluminum Xpress. The only main concern I really have is the boat ramp and tires slipping. Will I have any problems towing it?
PhiLambTitan is offline   Reply With Quote
Old 03-18-2008, 08:37 AM   #2
walleeme
walleeme's Avatar
Re: 2wd Boat Towing
Nope.
Have fun.
My has almost nothing compared to some of you guys, but I still like it.
MADE IN USA is the way things are supposed to be.
ACCEPT NO SUBSTITUTES.
walleeme is offline   Reply With Quote
Old 03-18-2008, 08:44 AM   #3
Megw3788
Megw3788's Avatar
Send a message via AIM to Megw3788
Re: 2wd Boat Towing
Nope, I tow a 20ft ski boat with no problems, never had my tires slip.
Megw3788 is offline   Reply With Quote
Old 03-18-2008, 08:53 AM   #4
PhiLambTitan
Re: 2wd Boat Towing
Sweet thanks for the help!
Old 03-18-2008, 09:16 AM   #5
anmut
anmut's Avatar
Re: 2wd Boat Towing
You should be okay towing it. Inspect the launch though before you put your boat in. Don't launch anywhere with a steep and/or gravel grade to it.
Also remember when you recover your boat from the water that with a two wheel drive it's sometimes better to keep more of the truck and trailer out of the water and use the trailer winch to get the boat on than it is to back way out. Oh and if the launch is wide enough and highly used try to back up out of the "wet marks" on the pavement.
This comes from a lot of experience watching n00bs at the launch ramps. I actually saw a guy with an older Jeep trying to recover a 25+ boat have to have his friends help push the vehicle up the ramp.
Mods: 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow · Nissan OEM Brush Guard · Hellwig Traction Springs · Jason Topper
Wish List: Nerf Bars · LineX Spray-In Bedliner
Waiting For Support On: TruTrac · UpRev
"I can't find anyone to race..."
anmut is offline   Reply With Quote
Old 03-18-2008, 12:20 PM   #6
Bullwinkle
Re: 2wd Boat Towing
Busy launch ramps are always good entertainment!
Practice backing down the ramp, launching, & retrieving the boat before you head to the lake on a busy weekend. Get a routine down. Ideally you need someone that can drive the truck (and back up the trailer), and someone else to drive the boat.
When launching the boat don't forget to check the bilge plug & remove the transom straps. When retrieving it, don't forget to put the outdrive up (assuming it has one).
Learn to get the boat in & out of the water as quickly as possible, but don't expect anyone else to!
'08 Titan SE, Crew Cab, 4wd, LWB, Smoke
Bullwinkle is offline   Reply With Quote
Old 03-18-2008, 12:35 PM   #7
Megw3788
Megw3788's Avatar
Re: 2wd Boat Towing
Haha ain't that the truth. Everyone will pressure you to hurry up and get out of the way, then you happen to get behind that same person the next weekend and they take 30 minutes to unload their stuff. We usually go to the port on Saturday or Sunday evening after we go out to the islands because the boat ramp is super busy, and it's right beside this nice resturaunt and boy is it some great entertainment. All the drunkies that have been out in the ocean all day trying to load up their boats, all the noobs that have the drunks at the Tiki bar yelling at them and pressuring them making them do even worse than they were, and then the first timers that try to pull their boat out and can't and have to have someone with a 4x4 hook to them and tow em out. lol Then there's the occasional truck that rolls back into the water. I've only got to witness two of those though.
Old 03-18-2008, 12:59 PM   #8
AgTitan06
AgTitan06's Avatar
Re: 2wd Boat Towing
You should be fine. I've never had a problem at the boat ramp with my 4x2. When you are pulling out, drop it in a low gear and ease into the throttle.
Just be careful. Don't let this happen to you! LOL
Old 03-18-2008, 01:45 PM   #9
anmut
anmut's Avatar
Re: 2wd Boat Towing
Ain't that the truth. That's why I'd rather hit the river than go to one of the many yuppie lakes. The river may be brown from the oak leaves but the launches are only being used by fishermen.
Old 03-18-2008, 02:08 PM   #10
Demondw3
Demondw3's Avatar
Re: 2wd Boat Towing
I have never had a problem towing, launching or recovering my boat with my 2wd.
check out my trucks transformation.
http://www.kodakgallery.com/Slidesho... y=8mexzr&Ux=0
Demondw3 is offline   Reply With Quote
Old 03-18-2008, 03:12 PM   #11
Megw3788
Megw3788's Avatar
Re: 2wd Boat Towing
Around here once it starts warming up every boat ramp gets packed. The ones in the river's, aside from the fresh water river, and the ones for the ocean. It's rediculous, you can count on waiting atleast 20 minutes to launch your boat, then you play heck trying to find a spot. And if you have to launch at the ramps at the port, it takes atleast an hour to get through the locks, and it's still packed at the ramps.
Old 03-18-2008, 03:47 PM   #12
DiabloDelSol
DiabloDelSol's Avatar
Re: 2wd Boat Towing
I had a friend who would launch and recover his heavy-a$$ sailboat with an old Ford two-wheel-drive with generic street tires. Occasionally, the ramp would be covered in a layer of algae. The truck would slip and spin its tires on recovery. Me and another buddy or just someone else at the dock would stand on the rear bumper. Problem solved. You just need a little weight on the rear tires for traction.
DiabloDelSol is offline   Reply With Quote
Old 03-18-2008, 05:29 PM   #13
yamatitan
yamatitan's Avatar
Re: 2wd Boat Towing
i never had a problem with my old 2wd f150. i did use some common sense though and wouldnt launch at a ramp that was gravel or was covered in algae, etc... If it looked effie i would find another launch. it didnt take long to learn where all the good launches where.
now i got a 4x4 and dont have to worry about that anymore yippee!
Procomp 6"
18" Procomp 8179 wheels
35x12.5x18 Toyo MT's
PRG Offroad Traction Bars
Banks Monster Exhaust
2* Timing Advance
Huskyliner floorliners
Volant Powercore
Tech12volt box with 2xkicker 12 and kicker amp
SAW coilovers
Bushwacker Pocket style flares:getting painted as we speak
Go Dominator type II: on the way.
Old 03-19-2008, 01:20 AM   #14
young dank
Re: 2wd Boat Towing
yeah I did a lil of spin on algae, dropped it in first and eased out. I been in deep mud and got out after diggin a trench. 2wd. thank you 1st gear.
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
young dank is offline   Reply With Quote
Old 03-19-2008, 02:34 AM   #15
anmut
anmut's Avatar
Re: 2wd Boat Towing
And who says it isn't fun to burn a little rubber on the launch anyway?!
User Name
Password
Towing the boat: THEN AND NOW AgTitan06 Titan Pictures & Media Post 10 09-24-2007 03:01 PM
questions before towing a boat phazetitan Titan Towing & Hauling 15 05-15-2007 07:30 AM
Boat Towing tailwaters Titan Towing & Hauling 13 02-20-2007 05:12 PM
Towing the boat with the New Wheels TruckinTitan Titan Pictures & Media Post 9 09-25-2006 11:48 AM
Boat Towing AKHUNT/FISH Titan General Discussion 3 02-14-2004 09:39 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
