Old 03-14-2008, 08:12 AM   #1 (permalink)
Running an Accessory while Towing
Trying to get the 12 volts to work for a 2005 Nissan Titan from the 7 pin connector that the trailer plugs into. From what I can tell, my truck has both Tow 1 and Tow 2 relays. Still cant get the 12 volt pin to light when I test it with a light. All other light functions work.. Brakes, Turns Signals etc.
tbourdaux is offline   Reply With Quote
Old 03-14-2008, 09:34 AM   #2 (permalink)
TitanTeamRoper's Avatar
Send a message via Yahoo to TitanTeamRoper
Re: Running an Accessory while Towing
Did you test with the key in the ignition and turn to on? There is not power to the plug unless it is turned on by the key; safety feature so if the trailer is hooked up for an extended period of time is doesn't drain the battery
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
TitanTeamRoper is offline   Reply With Quote
Old 03-14-2008, 10:32 AM   #3 (permalink)
baseballfanz's Avatar
Have you ever gotten the TSB done? if so they added a fuse by the BCM (under the steering wheel area. There's a fuse there too.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 03-14-2008, 11:04 AM   #4 (permalink)
The truck was running when I tested with the light. Still no power. Not sure if I know what the TSB is.
Old 03-22-2008, 07:14 AM   #5 (permalink)
Thanks, took it to the dealer. Took them four hours to figure out it was indeed the fuse under the dash that was blown.
accessory themes? gringo88 Titan General Discussion 3 06-11-2007 07:22 AM
Accessory fuse WazzuCoug Titan Parts & Accessories 8 05-19-2005 12:47 PM
A Must have accessory fellowx Titan Parts & Accessories 5 01-02-2005 02:54 PM
The best accessory ever nismotony Titan General Discussion 4 11-16-2004 07:22 PM
Which accessory to get? skycruiser Titan General Discussion 3 10-24-2004 02:53 PM
