Go Back   Nissan Titan Forums > Titan Discussion > Titan Towing & Hauling
User Name
Password
Big tow or not?? - being discussed at Nissan Titan Forums in the Titan Towing & Hauling section.
Old 03-23-2008, 10:09 AM   #1
RJacks258
RJacks258's Avatar
Big tow or not??
What is the difference between the Big Tow package and regular? I bought my 2006 Titan a few weeks ago, and it has everything but the tow mirrors. It has the Nissan 10,000lb Class IV hitch, tow/haul mode. But from what the manual says, there is almost a 2000lb trailer towing capacity difference.
RJacks258 is offline   Reply With Quote
Old 03-23-2008, 10:32 AM   #2
Sftail1990
Sftail1990's Avatar
Re: Big tow or not??
A search would help you wonders on this, lots of folks have asked about this, I for one have an 06 Crew Cab, the key for this year and a few others is on the dash, you must have a transmission temp guage to have the Big Tow on an 06. The other items with Big Tow is 3:36 gears, the Big Tow mirrors, but someone could have changed those out. The hitch would be a factory Nissan with the 7 pole plug and the relays for the harness on that wiring. You also get the heavy duty battery, Trailer brake prewiring. Now it does matter if you have a 4x4, then some of this stuff comes with Off-road as well. The trans temp guage in the factory cluster on the dash would be the dead giveaway to the Big Tow, that is the hardest to install if it didn't come with the Big Tow.
2006 Titan SE CC w/ Big Tow
Chrome Package w/chrome 18" 6-Spoke
S&B Intake w/AirRaid TBS
ReTrax Bed Cover
Axle Vent Mod
Sftail1990 is offline   Reply With Quote
Old 03-23-2008, 10:37 AM   #3
Arachnid
Arachnid's Avatar
Class IV receiver hitch
Additional 7-pin wiring harness plug
Trailer brake controller pre-wiring under instrument panel
Heavy-duty battery (710 CCA)
Lower final gear ratio (3.36:1)
Extendable tow mirrors (N/A on XE)
Increased tow capacity
Front tow hooks
AKA: Critter Whore™
Arachnid is online now   Reply With Quote
Old 03-23-2008, 11:03 AM   #4
RJacks258
RJacks258's Avatar
Front tow hooks
I have the 7-pole harness, The pre-wiring for the controller (had to buy the other connector from Nissan to plug in), 710CCA battery, Tow hooks.
I don't have the big mirrors or the tranny temp gauge. And I am unsure, but I think I have the 2.93 gears.
Truck is an '06 CC LE 2wd.
Old 03-23-2008, 11:10 AM   #5
GlendaleTitan
GlendaleTitan's Avatar
no gauge..no big tow....simple.
GlendaleTitan is offline   Reply With Quote
Old 03-23-2008, 02:37 PM   #6
Just-in
Just-in's Avatar
Don't let it getcha down though. I had an XE w/o the BT package.
The 5.6 can pull it's own. (No pun intended)
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
