Old 03-25-2008, 04:03 PM   #1 (permalink)
Break controller lead?
Sorry meant- Brake
I think this is a brake controller lead. What do you think?
Looks like something was mounted right here:
'04 Titan LE- MX bike hauler.
Howorks is offline   Reply With Quote
Old 03-25-2008, 06:16 PM   #2 (permalink)
Send a message via AIM to Jared
Re: Break controller lead?
hard to see what you are pointing at but i dont think its the brake controller harness.
MY06 Smoke Titan SE CC 4x4 Tow
Nismo Cold Air, Banks Monster, Nismo Headers,
2.5" leveler
ASE Master Technician
Nissan Master Technician
AEM Trained
Jared is offline   Reply With Quote
Old 03-25-2008, 06:29 PM   #3 (permalink)
Carbeaux's Avatar
It probably was, but without knowing what brand controller it was hooked to, you're kind of at a disadvantage.
The good thing? When you decide on the brand you want, it'll be easy to replace that harness with the correct one.
Hook 'Em Horns!
- Frank Zappa
Old 03-25-2008, 06:54 PM   #4 (permalink)
Derwud's Avatar
Brake controller harness
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 03-25-2008, 10:10 PM   #5 (permalink)
loufish's Avatar
That's NOT the brake harness. it's the OBD II connector for diagnostics...Where you would plug your scanner into...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 03-26-2008, 03:53 AM   #6 (permalink)
hkusp45's Avatar
His pointer is pointing behind the OBD.
I found my connecter for the harness way on the left side above the e-brake. It was even flagged with a sticker for it.
First an 04'
Now a new 2008.5!! I love these things!
hkusp45 is offline   Reply With Quote
Old 03-26-2008, 04:32 AM   #7 (permalink)
roy365's Avatar
That's the OBDII connector!!!! Isn't the brake controller on the left (opposite) side?
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 03-26-2008, 04:45 AM   #8 (permalink)
roy365's Avatar
Now thats what I call "plug n play" there!!!!!!
Old 03-26-2008, 05:45 AM   #9 (permalink)
loufish's Avatar
See what happens when you post dead tired...It's time for a Monster!
Born 9/2004
2002 Honda XR650R
Old 03-26-2008, 06:03 AM   #10 (permalink)
Derwud's Avatar
It looks as though someone already had a brake controller hooked up on the truck and the brake controller harness is hanging below the OBD II plug..
As to the OP get the Plug and Play harness from an RV store with your brake controller and you will find the connector, cause it will be the only one you can plug it in too.
Old 03-26-2008, 06:11 AM   #11 (permalink)
roy365's Avatar
Ah......the black arrow disappears unless you look real hard. Plus with the scratches and holes it was kind of misleading.
Thats prolly what they had screwed into the dash part huh?
Old 03-26-2008, 10:36 AM   #12 (permalink)
Thanks for the replies. I'm guessing the previous owner had a brake controller mounted where the holes are now on the panel. And that little plug was connected to the brake controller. I was hoping that someone could identify which brake controller it was. That would make it easy for me to just get the same one- as long as it was a good one!
Old 03-26-2008, 10:51 AM   #13 (permalink)
hkusp45's Avatar
How about a better photo of the plug?
First an 04'
Old 03-26-2008, 11:13 AM   #14 (permalink)
Will post a better picture tonight
Old 03-26-2008, 09:57 PM   #15 (permalink)
Any better?
12Volt Power Lead racerjack Titan Towing & Hauling 6 07-28-2007 09:50 AM
[B]Amp Turn On-Lead[/B] sammytay Titan Visual & Audio Discussion 5 03-04-2007 07:47 PM
Break Controller ApoKalypsE Titan Parts & Accessories 17 07-07-2006 05:50 PM
A question for all you lead foots. NKYTITAN Off-Topic Discussion 7 11-15-2005 01:32 PM
Reverse Lamp Lead? nizmo04 Titan Interior Discussion 1 02-07-2005 12:55 PM
